SOURCE: power window fell down inside door
there are clips holding the door panel around the edges. to remove the clips, use a small screwdriver to feel for them, then use another one to pull the panel on the other side. Pull outward from both sides of the clip until it comes loose. Do this repeatedly, and then loosen and remove the arm rest.
Pull the window up and have a helper hold it as you work it back into the track.
Good luck.
SOURCE: saturn ion fuel pump
Misnikie32 . .. I just had the same problem around the time you figured out your problem and I just got it fixed yesterday. For almost 3 weeks I had starting problems and I constantly smelled gas. The problem is a safety issue and the car needs to be recalled. The hose that is connected to the fuel pump is cracked. Since the hose is incorporated with the fuel pump, the entire mechanism needs to be changed. Look at spending about 700.00 . I informed saturn and told them my life was at danger. Please contact them on their website and goto your state's attorney general and launch a complaint, as well as the office of defective investigations and the NTSAB (google them). This needs to be brought to their attention and all owners of this car. I googled this and many other people are having this problem. Some are even on this forum. PLEASE DO THIS ! ! ! !
SOURCE: I have a 2006 Saturn Ion. It started running
You can by a new Coil pack from Auto Zone for less then the dealer's cost and Auto Zone can give you the step by step instructions for you to replace the coil pack free of charge and will take about 1 hour if your good with common tools. Auto Zone also can scan your car for DTC codes Free of charge to ensure that it's the coil pack. The other common problem that will also seam like a bad coil pack is a bad ignition module which is what I am leaning towards since it's three of the cylinders you mentioned, most of the time it's just one of the two coils that will go bad which would only make two of the cylinders go dead. Check the wires to the electronic module first and then the switch the coils and see if the same two cylinders are still dead, if the same cylinders are still dead. Good chance that it's going to be the module and if the other two cylinders go dead and the dead ones come alive then it's going to be the coil pack. Good luck and here is a you-tube link to the ignition module and coil pack replacement procedure. keep me posted, be glad to know you got your car running 100% again . http://www.youtube.com/watch?v=8XgHM1i5jK8
SOURCE: where is the battery located in a saturn ion
MIGHT BE IN TRUNK UNDER SPARE TIRE COVER G5 IS IN THE SAME PLACE,CAN'T HURT TO LOOK.
