My aucma tv does not show all the channels yet it is a dtv and when i select a channel it says channel is encrypted contact your local retailer for information
    Top Expert:
  • Televison & ... Master
  • 77,939 Answers
You need a cable box to decrypt the signal, sorry that is the issue.
Posted on Dec 15, 2016
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
Posted on Apr 30, 2008
  • 1214 Answers
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Posted on Feb 16, 2009
SOURCE: ''Select DTV channel for OAD'' screen and can't remove
**This is NOT a solution**
I was wondering if you were able to fix this on your own. I am have the exact same issue with a 42LG30
Posted on Dec 07, 2009
  • 2335 Answers
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Posted on Dec 26, 2009
  • 635 Answers
SOURCE: New LG 32LD350 - Allowed TV to auto-program
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Posted on Mar 11, 2011
How do I access DTV channels? It always indicates 'Database Empty'
When you set up the tuner select analog + DTV and then do a channel search.
Jul 10, 2014 | Sharp LC32D44EBK 32 in. LCD TV
Unable to to get cable channels in modulator. Set to cable, channels 73/75 but "connection" grayed out. Cable signal strong. Able to read Digital channels on Local set up with same i/p.
The connection button is not utilized from the "Modulator Setup" screen. When changing the channel for TV 2, you can arrow over to either air or cable and pressing select. This will select that option and change the channel to either 60 for air or 73 for cable. Once this selection is made then you would move to the "Done" button and press select. You will return to the "Installation" menu, then cancel out till you are back to the TV screen. I hope this helps.
Ray Calo
DISH Network
Dec 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Why can't I tune in new channels from set top box through vcr?
Sounds like you are trying to receive the new Over The Air OTA, digital ATSC signals on a VCR that can only receive analog NTSC, which are not sent by any but low-power channels. Did you miss the change over last April, postponed from Feb, and featured on every TV channel when you could have obtained 1 or 2 $40 coupons toward ATSC-to-NTSC converter boxes. Try for more info, IIRC.
If you are speaking of cable TV then see your company. These may be digital Quadrature Amplitude Modulation QAM signals that only certain TVs can decode provided they are not encrypted. Locals are never encrypted. This is separate from the ATSC conversion.
Oct 04, 2009 | Quasar VHQ940 VHS VCR
I cannot get a signal with converter box and Philips indoor antenna
Try to manually enter the local DTV Station Channels, instead of letting the converter scan for channels. And try moving the antenna and then re-entering the DTV channel.
You should really have an external antenna that is matched to your local reception needs.
contact your local TV stations, their engineers will be more than happy to help.
Jun 15, 2009 | Durabrand DWT1304 13" TV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
No local channels
make sure u are gettin a signal on the 72.5 if you are call dtv and have them reauthorize the locals to your receiver. they can send a signal for a force download
Jan 03, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Unable to detect some local DTV channels
chec kthe settings
they might be at fault
Sep 06, 2008 | Computers & Internet
SYLVANIA LC200SL8 ? 20" LCD-TV Settup up channel setup
This is the chanel set up options I see on the online manual:
! CATV takes approx. 50min.
To set up for over the air broadcast that local channels now have in HDTV, you will select AUTO PRESET CH(DTV). You will have to disconnect cable for this option; however, the cable company will send local channels over the cable.
Bottom line, if you have cable, use it, it will most likely still deliver the best signal.
So coonect cable and use this option:
Oh, and the reason it takes so long is because there are more channels to scan with cable then with the local over the air channels.
Aug 23, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
