Question about Whirlpool Washing Machines
Whirlpool Washer water inlet valve
I have a Whirlpool washer LSB6300PW2. When the water begins to fill, I hear a sort of high pitch screeching noise for about a second, then all is fine. When the rinse water begins, there is the screech noise again, for about one second, then all is fine again. Also, on occasion, when the water begins to fill, I notice that it seems to be a low flow of water for a few seconds, then all of a sudden it switches to more flow (like the pressure was increased). I'm thinking that the problem lies with the water inlet valve. What is the correct Part # for the Water Inlet Valve? I googled my washer model and all that comes up is is: LSB6300PW1, or LSB6300PW3. But I can't find LSB6300PW2.. I am certain my model is LSB6300PW2 because that is what is imprinted under the top lid of the washer. I am looking for the OEM Genuine Whirlpool part, not a generic. THANKS AND BLESSINGS !! Also, where is the part # imprinted on the water inlet valve? In other words, if I remove the top cover of the washer, would I be able to see the part # imprinted on the water inlet valve without having to actually remove the water inlet valve? (I would like to make sure I order the correct part before removing the existing valve)
  • Stella Ab Dec 15, 2016
    What link? I don't see anything.
  • richie46 Dec 15, 2016
    WWW.appliancepartspros.com
  • Whirlpool Master
  • 8,136 Answers
Go to the enclosed link with the exact model number of your appliance and you will get the appropriate part number. You can buy from them or check it out on ebay where , very often, the part will be available for less money.
Posted on Dec 15, 2016
Testimonial: "What link? I don't see a link. Thank you !"
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
Does not fill with water.
Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve. Replace the "water inlet valve" with this part.
Dec 31, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool lsb6300pw2 top-loader. Spinning is not always complete if at all. The tub usually drains fine it is just the spin cycle that for some reason is not happening. If the washer is reset...
Hello. I also have a Whirlpool LSB6300PW2. Do you happen to know what the Part # is for the WATER INLET VALVE? I googled my washer model and all that comes up is: LSB6300PW1, or LSB6300PW3, or LSB6300PW4 . But I can't find LSB6300PW2.). I am certain my model is LSB6300PW2 because that is what is imprinted under the top lid of the washer. I am looking for the Genuine OEM Whirlpool Water Inlet Valve, not a generic. THANKS !
Jan 04, 2010 | Whirlpool Washing Machines
Our machine functions correctly, but makes a high pitched -
need a new fill valve that what it sounds like check to see if your water is turned all the way on that can do it to.. and yes you can get parts for it
Jan 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Doesn't Wash Clothes, But It Rinses Clothes
hello. i can help you.
Jun 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
High pitched noise
The inlet valve is faulty and needs to be replaced.
Nov 03, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Lady Kenmore Washer
Possibly a bad fill valve. If you're hearing a noise, it sounds like the valve is getting power, but isn't opening to allow water in, or is clogged. I would check your valve inlets on the back of the washer, first. Turn off the water and disconnect the hoses on the back of the washer. The water inlet screens are located in the valve fittings. Take a cotton swap and clean them out thoroughly. If they are clear, you may want to invest in a new replacement valve. Let me know if you need to pursue this option and I can give you the steps necessary to replace. It's not a very difficult repair job. I hope this helps you.
Aug 09, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
