When switching on my reversible air heater pump. The fuze blew very quickly. Since then, each time I turn on the power, after a few seconds and before the external unit activates, the fuze blows.
The air heater is an Aircon (French made) double unit having one blower and control unit fitted high on the living room wall, and the compressor/fan unit fitted on the ground outside. Model number is TAC-18CHSA/H ref: 405595.
  • Heating & Co... Master
  • 1,871 Answers
Sounds like compressor shorted to ground or a short to ground in wiring.. not good
Posted on Dec 17, 2016
  • sammacd Dec 17, 2016
    Thank you Thomas. Your assumption coincides exactly with another on-line oracle. So I think that this is the problem exactly. :-)
    Very helpful. Thank you
I just bought a Coleman air mattress. It has an electric pump that blew it up quickly. There is another device to use to deflate it. My question is how does that work? Thanks!
Hello.
The fitting goes on the air inlet side and causes the blower to pull the air out of the mattress, that is, you use the same pump to reverse the air flow.
Best regards, --W/D--
Mar 20, 2011 | Sport & Outdoor - Others
My Sansa Fuze 4gb wont turn on and isnt being recognized by my computer, iv also tried to soft reset it many times , nothing seems to work.. help plz..
I've had the same problem with my Sansa Fuze 2GB. It's pretty frustrating, but in order to get it to work, I let it sit without touching it or doing anything with it for a few days. For 2-5 days, do not turn on your Sansa Fuze. After the amount of time has passed, try the soft reset again.
Apr 22, 2010 | SanDisk Sansa Fuze MP3 Player
Air suspension is dead on the ground fuse is good will not raise?
Check the suspension switch on the trunk, I think is on the driver side, something should happen if you turn it on/off.
Sep 17, 2009 | 1994 Lincoln Town Car
Power steering hose blew
Generally it should work it's way out by itself, but you can remove air by turning the wheels all the way in one direction (hold it there a few seconds) then repeat in other direction...check fluid level and that's all. If noise lasts more than a few hours, then pump has sustained some damage.
Apr 22, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
OVER HEATING
In the fan circuit...You have a temp switch screwed on the radiator, a fuze and a relay in the fuze box plus a fan.  Swap the relay with another relay, replace the fuze.  The other fan should come on when the a/c is turned on.  If you fix the fans and it still overheats, you may have a BLOWN HEAD GASKET.  ALSO ARE YOU BLEEDING THE AIR FROM THE SYSTEM?  DO YOU SMELL EXHAUST IN THE COOLANT?
Mar 12, 2009 | 2000 Volkswagen Beetle
Heat pump that just blows cool air
is the condenser operating? what is the outdoor temperature? A heat pump is a cooling system with a reverse gear, most reversing valves which make this possible fail to the heat mode so it is not likely to be the problem. You should have either gas or electric back-up heat. If you switch to emergency heat do you get warm air? Really need to find out more to make an informed guess at your problem, the simple stupid would be is the circuit breaker to the condensing unit possibly tripped or shut off?
Dec 18, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
