Question about Kenmore Washing Machines
Kenmore model # 110.82873120 fills, washes and drains fine but spin cycle is slow and clothes are dripping wet at end of cycle.
  • 96 Answers
SOURCE: series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Posted on Mar 20, 2008
  • 21 Answers
SOURCE: wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Posted on Dec 29, 2008
  • 19 Answers
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Posted on Jan 25, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 155 Answers
SOURCE: slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Posted on Sep 02, 2009
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Mar 02, 2009 | Kenmore 43142 Front Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Spin cycle not working properly, clothes still wet!!!!
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Oct 29, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
