Question about Fast Computers & Internet
Can I switch fast rack dc set up to act current and use the trains that I purchase d in the kits? Are they doc powered?
One in the silver bell express and the other in the penn flyer kit
SOURCE: change timing belt and idle speed servo kit.
send me your e-mail so i can send to you full repair instruction and picture
Posted on Dec 27, 2008
  • 6982 Answers
SOURCE: power steering leak on 97 camry
likely somebody makes a rebuild kit, but, I'd just replace the rack.
Posted on Apr 02, 2009
  • 556 Answers
SOURCE: Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Posted on Aug 10, 2009
SOURCE: Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Posted on Dec 19, 2009
Testimonial: "Thank you! Now... how do you keep it on the track? :O)"
SOURCE: No power to track and/or train. Power to Holiday Express Train
Power enters through the tender. You must have the tender and the engine both on tracks and linked with electric cable.
Posted on Dec 31, 2009
Why did my Lionel fast tracking crossing quit working the bell works but not the gates or flashers
these are real neet , there a combination of a few great items to all in one device , this device consists of two automatic crossing gates , one track automatic detector and of course a automated bell , well first thing to do is to look real careful at the track detector , these wont work if there under any stress or leaning (as this is the principle of there operation) so first see if track is twisted or leaning as it enters the device ? if all is good make sure that detector is not damaged or there isn't any foreign objects down inside it (for me its always those darn pine needles off the tree) , the reason the crossbucks don't light is that gates arnt moving , the switch for them is inside the motor housing that moves the gates
Mar 20, 2016 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
I have a tyco ho scale silver streak train set and do not know how the wires connect from the transformer to the track. theres one side for accessories and the other for train
the transformer shave a knob that makes the train go and go faster as you turn it
some have the knob in a central position so that one way is forward and faster or the other way is reverse and faster
accessories is for boom gates , lights , anything else that you have set up to operate besides the train
Aug 05, 2017 | Chattanooga Bachmann HO Scale Train Set
How can I operate my LG 26LE5300 LED LCD TV in my motorhome the most direct way possible (i.e....without an inverter)? This low power (40-50 watts) TV has an external brick to convert 120 AC to it's...
1) You need to look at the output current rating (AMP) of this AC to 24dc adapter, this 24vdc adapter is a regulated switching power supply that will maintain 24vdc output up the maximum current rating and also has shutdown circuits if the over current draw is detect and also if the output voltage goes up beyond 24vdc to protect the load (TV).
2) To use 12vdc to 24vdc DC-DC booster, it should have the following spec:
A) The output current rating should be at least 20% higher than the load requires to give its head room.
B) It must have regulated output that will maintain the 24vdc when the input (12vdc) will vary from 10vdc ~16vdc or higher since your batteries will not maintain exact 12vdc all the time.
C) It must have good protection circuits that will protect it self from reverse polarity connections, shorted output protection, over voltage output protection.
D) It should provide AC ripple spec on the 24vdc output, it should be in the milli-volt range (you will always get AC ripple riding on top of DC when you rectify the AC into DC).
These are the minimum requirement for your DC to DC booster, which you need to protect your TV and your motor home from burning down.
I hope I explain it OK to you.
Please leave rating if it helps.
Basic troubleshooting guide here:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | LG 26LE5300 26 in. LCD HDTV
I have power to the track and the controller, but not the train.
I assume you have the Treetop Tender car on the track? The treetop tender is car that makes the electrical connection between the track and the train.
1. Use a volt meter across the track. You should have about 10.5VDC on the track (anywhere on the track)
2. Even without the Loco on the track, the Treetop Tender should light up if you have power to the track. If you have power and the tender does not light. Check the brushes located between the wheels on the tender. These are the motor brushes that pick up the current from the track for the train set. Make sure they are contacting the track.
3. Add the loco to the track and plug in the large black plug from the tender to the loco. Turn on the power and press forward. The train should start rolling.
Try all the functions, bells, ho ho ho, all aboard etc ..
Add one car at a time and make sure that each one lights up before moving on to the next.
Dec 05, 2009 | New Bright 384 Holiday Express Animated...
Digi002 Rack
Reinstall the driver with the unit dissconnected. Check to make sure your version of OSX is stable with your current version of Protools, especially if youve done any software updates.
Keep me posted.
Aug 30, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Computers & Internet Logo
Top Fast Computers & Internet Experts
Eric Sutherland
Are you a Fast Computer and Internet Expert? Answer questions, earn points and help others
