Question about Garden
I have a older bolens garden tractor that over charges the battery
When i purchased this tractor it would not charge the battery, so i replaced the voltage regulator and worked, but over charged the battery. i found an NOS regulator but still over charges.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 242 Answers
Are you sure you did not mix your wires or they were mixed when you bought it? Two of the wires that come out from under the flywheel should be the same color go to the outside spades on the regulator and the center spade is to the battery , probably by way of through a gauge and key but for test purposes it will be the wire that feeds about 13.8 DC volts to charge the battery, the two outside spades on the regulator that have wires that go back under the flywheel are ac voltage anywhere from 18 to 38 volts depending on RPM of engine . Yours is a voltage regulator, Rectifier, converts it to DC and regulates it at 13.8 volts DC
Posted on Dec 15, 2016
  • Wayne mattson
    Wayne mattson Dec 15, 2016
    there are four wires coming from the flywheel, 2 black and 3 red wires, the two black wires go to rectifier,should both red wires go to regulator side.
  • Richard Schanie Dec 16, 2016
    which engine is this, Tecumseh ? Are the points under the flywheel?
Black&decler cordless garden shear GSJ35. Purchased may 2014. Very little use. Problem: when charged (overnight) will only run for a couple of minutes. Please advise.
Battery has failed probably die to being left on the charger. Non use is the worst thing for battwries...especially older nicd ones.
Nov 01, 2016 | Garden
1968 Bolens 1220 garden tractor. Why does it grind badly and won't go into gear?
Search Results
    replacing a shift fork in a bolens garden tractor - YouTube
    ? 8:25
    www.youtube.com/watch?v=QOjDF3uPS3U
    Feb 16, 2012 - Uploaded by Tyler grigg 600 700 800 900 1000 650 750 850 1050 854 853 1054 1053 12201225 1253 1254 1256 1257 1556 g9 g10 .
Oct 08, 2015 | Garden
Charging on st120
Bolens, really old? Which engine company
Apr 08, 2014 | Garden
Lawn tractor wont start
How do you know the battery is fully charged? Simply hooking a battery up to a charger does not ensure that the battery is being charged. The symptoms you mention are indicative of a dead battery.
Jan 29, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Craftsman lawn tractor
charging system need to be check... alt. some of these tractors have the charging reg. inside alt some have one mounted outside follow wire the red one should be one big (thick) one and a thinner (smaller one) this small one is the charging circuit. if it goes from battery to alt. then regular is inside alt.
Oct 04, 2017 | Craftsman Garden
Battery won't charge
First, have the battery load tested at say...Autozone, Advance, ect...and see if it is capable of a charge . If not, replace it. If it is good, clean the battery terminals to insure a good connection. You didnt state what kind off mower you have, so I can only guess. If you have a older regular riding mower, most do not come with a charging system. Most batteries will maintain their charge of 12.6 volts all by their selves, if it wont hold at least 12.6 volts, it will need to be replaced.
Mar 11, 2012 | John Deere Garden
I have a Bolens riding mower. It worked fine yesterday, but when i went back out to finish yard it wouldn't start. Tried to charge battery but that didn't work. Any suggestions? Thanks in advance
I suggest that you check to make sure that your mower's blades have been disengaged. There is a safety switch that will prevent restarting if your mower's blades are engaged.
Jul 07, 2011 | Garden
My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
Mar 26, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Will only start once after charging all night.
Make sure battery is not over heated (suggest bringing battery in home/room temp to cool down 1st) Clean contacts of battery ideally with alcohol swab or very slightly damp cloth, white calcium build up can cause poor connection clean wire clamps connected to battery also HAS TO BE BONE DRY Make sure you didn't flood gas driven mower. Simply give mower time to cool down Patience rules with problem solving/trouble shooting always explore easiest solutions first Spark plugs cleaned oil checked and filters cleaned also maybe simply too damp to function
Aug 07, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
