Question about Ovens
I have a single door Frigidaire,Frost free,How do I get the glass out of the Veg,glass out to clean under the bar in the center
SOURCE: Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Posted on Oct 15, 2008
  • 2920 Answers
SOURCE: Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
you should be able to just replace the glass
Posted on Jan 12, 2009
  • 107 Answers
SOURCE: Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Posted on Mar 25, 2009
Maytag317
  • 1136 Answers
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • 3600 Answers
SOURCE: loose/broken seel on inner door glass of oven
Yes it is still avalible I looked it up and there is one in Texas here is the number to order. Genuine Parts & Accessories (800) 935-0062 please rate if this helped.
Posted on Aug 07, 2009
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
Clean glass range door
Hello. I recommend a product called Cameo. Cameo is a non abrasive cleanser actually designed for the new type enameled sinks recomended by American Standard. AND iit works great on oven door glass. You can get it at Walmart. Very inexpensive and works great on all kinds of surfaces that may be hard to clean but you don't want a harsh cleaner that might damage the surface or scratch. Has a very light to almost none scent. Very good for cleaning the oven both inside and out. Doesn't have the chemical smell left by some cleaners that can be intensified by heat.
Aug 14, 2009 | Frigidaire 27 in. Electric Gallery Pro...
GLASS BROKEN ON MY FRIGIDAIRE PRO
Inner or outer? you will have to take the door off, done by lowering door to full open postion and youll see a fold down flap at hinge, fold down and close door and lift. this will allow you to access screws easier. remove handle and four bottom screws. that will allow you to take off outer glass....there will be screws on inside to take out inner glass.
Jun 08, 2009 | Frigidaire FGB24S5A Gas Single Oven
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Glass oven door
We Use DeBruce Polish on all our cooktops. DeBruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Oct 27, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
