Question about Cycling
Can i buy 26in wheels with heavy duty spokes for my scwhinn maridian trike? and if so where can i purchase them from?
Ive broken spokes on the rear wheels and want spokes that will be more durable
    Top Expert:
  • Cycling Master
  • 8,211 Answers
You could try looking around the internet or try ebay.
Posted on Dec 15, 2016
Testimonial: "ive looked on the internet for days and found nothing. my next question is... CAN I DRILL THE HOLES ON THE RIM AND HUB TO THE CORRECT SIZE AND THEN BUY HEAVY DUTY SPOKES AND REPLACE THE ORIGINALS WITH THE HEAVY DUTY SPOKE"
  • NOEL
    NOEL Dec 15, 2016
    sorry this i would not know,if i find anything out i will get back to you.
  • Cycling Master
  • 1,206 Answers
Because the Meridian takes special hubs due to it being a trike your only option is to have a shop obtain the largest diameter spokes that will fit your hubs, either drill out your rims or obtain rims to fit larger spokes, and then build up the wheels. It will be expensive.
If you bike is older and has just started to break spokes, rebuilding with the same gauge will probably be sufficient.
Posted on Dec 16, 2016
Testimonial: "DRILLING THE HOLES IN THE RIM AND HUB IS NO PROBLEM AT ALL, finding and getting the right spokes would be the hardest part for me. Ive respoked a few rims and can get them farely close to being straight.If you can give me the correct lenght and where i can get them i would do the whole job myself"
  • Donald Ayers-Marsh Dec 17, 2016
    Drilling out the hub too much could weaken it, reversing any gain from thicker spokes, unless the difference is very small. The length is the same as the spokes are now, of course, assuming you build them in the same pattern. Spokes are measured from the inside of the curve at the head to the end.
    Go to a bike shop to see what diameter will fit, or you could just buy 12 gauge spokes, and drill the hub and rim ONLY as much as necessary. The spokes of course must be able to both fit through the hub hole and seat fully at the bend. 12 gauge spokes are available from a variety of sources - just Google "12 gauge spokes ___mm". You can get away with 1-2 mm shorter, longer only if current spokes are well below the slot in the nipple.
    Again, LOTS of people, including those who are quite heavy do fine with the original diameter. If the spokse are old or have not been kept to proper tension, they will break dur to uneven stress and flexing fatigue, not because they are too thin. A good quality 14 gauge stainless spoke will be fine for almost everyone.
Loose wheel
Hi Anonymous, rear axel nut torque is 65 ft lbs. but if you have a spoked wheel you could have broken, missing or loose spokes. Take it to your local dealer or reputable shop and they can fix you up. Not many people out there that know how to relace and true a spoked wheel. WARNING!!!!! do not attempt to retighten spokes your self you will end up with an egg gauranteed. Good luck
Apr 16, 2014 | 2009 Harley Davidson XL 1200C Sportster...
How do I change the back rim on the bike?
To change just the rim is a pretty big job, since you would have to remove every spoke and assemble a new wheel. But maybe you are asking how to straighten the wheel? If the bend is a bit of a wobble, and not a sharp kink, then you can usually true-up the wheel by adjusting the spokes. If this happened kind of suddenly, then you probably have a broken spoke. Pull on every spoke one at a time to see if that is the case. If none are broken, then you only need a spoke key. There are several styles, all pretty cheap, but they aren't all the same size. Look on YouTube for a how video on trueing bike wheels.
If you do have a broken spoke, and it is on the left side, then it's not too hard to replace. Just get the right size spoke and spoke key and you can do it without even removing the wheel. If you have a broken spoke on the right side you will almost certainly have to remove the wheel from the bike. There are several types with corresponding different tools and can be a bit tricky. Look for info on Parktool.com
Jun 21, 2012 | Cycling
My 1970's schwinn suburban has 5 broken spokes on the real wheel. where do i find rear whell replacement ?
You can have the spokes replaced and the wheel trued and tensioned much cheaper. Bike Shop either way.
Jul 25, 2011 | Cycling
Broken spoke in rear wheel. What could have caused it and is a replacement simple?
I ride a Trek 6.9 and have had spokes break for no apparent reason. Most of the time the spoke will break from over tightening on initial installation or just plain fatigue. Replacing the spoke is fairly straight forward. Remove the wheel from the bike and remove the tire. Remove the protective tape on the inside of the wheel to gain access to the spoke nut. After replacing the spoke you must make sure the wheel is true. If you do not have a set up for this, reassemble the wheel with the new spoke and take the assembly to your nearest bike store. They should have the equipment to true up your wheel assembly
May 31, 2011 | Dahon 7 Speed Folding Bike
A spoke on the rear wheel has snapped off how can I repair it?
Simply buy a replacement spoke. Unscrew the dustcap on the tyre valve and deflate the tyres inner tube. Remove tyre using tyre levers(as you do to repair a puncture). Next remove the inner tube to reveal the spoke tensioners. undo the tension nut and allow the broken spoke to fall out, feed the other part of the broken spoke out of the hub. feed the replacement spoke through the hub and into the hole on the wheel rim. Now screw on the tensioning nut to the spoke.Tighten up to the same tension as the other spokes. replace inner tube and tyre, then reinflate. Viola!
Jan 30, 2011 | Cycling
Rear spoke is broken, how do I remove the gears so I can fix it
Hello. Actually you do not need to remove the gears or even the wheel to replace a broken spoke. If you are mechanically minded and have tools just let the air out of the tire, pull it to one side and replace the spoke. If you do not have the tools, go to a bike shop for this quick fix. J.
Jun 14, 2010 | Shimano Aluminum 26" 7speed Mountain Bike...
Broken spokes on rear wheel
It is not that hard to replace a few broken shokes. All you have to do is take the rim off the bike and take the tire off of the rim. Install the new spokes and tighted them to the specs and put everything back on the bike and take it for a ride. After riding, I would check the spokes and retight to make sure there ready for your next ride.
May 07, 2010 | 2000 Yamaha V Star Classic
Motorcycle wheel
I m an MX rider and spokes must be done professionally. Once spoked locktight is used. Ive seen my friend break 7 ribs on a fall when the spokes he replaced collapsed on a jump. 2 months no riding and R1000 damage.
Sep 21, 2009 | Computers & Internet
Cycling Logo
188 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
