Question about Fisher and Paykel Dryers
What if my carriage bolt did slip back enough and all the insides hit the bottom , now what , degx2 dryer fisher and Paykel
IrishDruid
  • 2712 Answers
SOURCE: Fisher & paykel Dryer
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour or is not drying properly, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 28, 2008
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
ginko
  • 19396 Answers
SOURCE: my Fisher Paykel dryer DEGX2 WAS TAKING LONGER AND
Hi.
There is no reset circuit.
Parts that must be tested are high limit thermostat and timer board.
The timer board is replaced if it is visibly faulty, or if there is no problem elsewhere.
The high limit located near to the element is tested reading impedance with a multimeter set at Rx1. If there is no continuity , the thermostat must be replaced.
Before testing parts check the lint filter, and ensure that air ducts are clean.
Regards.
Posted on Nov 13, 2009
heatman101
  • 43501 Answers
SOURCE: My Fisher Paykel DEGX2 dryer is stuck. The drum
A dryer2_bing.gif may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 26, 2010
  • 10865 Answers
SOURCE: I have a
Hello. The squeaking is likely your rear bearing. The only fix is to replace it. Regarding those self-leveler feet, go to searspartsdirect.com and enter your model number. You will then see a complete set of diagrams showing exactly how each part fits into another. Joe
Posted on Oct 25, 2010
Fisher paykel troubleshooting
place your hands on the drum and push it backwards . the door will open when it comes around .
Jul 19, 2014 | Fisher and Paykel DEGX2 Dryer
Dryer moisture sensor not working
coolblueworld.com is fisher paykel wed sight
Mar 07, 2014 | Fisher and Paykel Dryers
Service Manual for DEGX2
Get the model # and go to Fisher Paykel website for info or to order the service model. Also you can enter your model and it will show you a breakdown on parts.
Mar 17, 2013 | Fisher and Paykel DEGX2 Dryer
My Fisher and Paykel Model Degx2 The drum is stick it will not open. Can someone help me please
see this and fix it. God bless you
If your electric dryers control is locked try the following. First make sure there is not a seperate control lock button if there is press one time to unlock. Next locate the end of cycle button and press and hold for 3 seconds. If this does not clear it press and hold for 15 seconds. Still not cleared shut off breaker for 5 minutes if this does not correct the problem replace the main control.
Sep 28, 2012 | Fisher and Paykel DEGX2 Dryer
Squeal when dryer turning
The problem is that your dryer needs a new drum bearing.
Jul 25, 2010 | Fisher and Paykel DEGX2 Dryer
Won't heat - otherwise acts normally....
You could check for obstructed vent of excessive lint.
I have an old dryer manual for fisher/paykel
for the x1, how different can they be? LOL
Oct 22, 2009 | Fisher and Paykel DEGX2 Dryer
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Open Questions:
Dryers Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
