Question about Miscellaneous
Pump will not start-in airing cupboard-tested pump and pump ok what do you think
08 Nissan, rogue turns over but wont start
I can think of 10 things right off the top of my head that could cause that--all require testing. No easy fix here
Nov 30, 2017 | Cars & Trucks
I have a 2000 sunfire and it cranks won't start though I have fuel from the pump I've checked all my fuses but I haven't got to the relays just yet I drove it to somewhere and it wouldn't crank afterward....
You need the basics to start the engine - fuel, air and spark. Your MAF - Mass Air Flow sensor could be dirty. Buy some sensor cleaner from auto parts store and clean it and let it dry. If that doesn't work test for spark if spark ok then bad fuel pump or fuel pump relay.
Aug 18, 2017 | Cars & Trucks
Ferroli optimax 25 c heating won't come on
Did you ever find out what this was as I have the same problem??
May 03, 2012 | Heating & Cooling
V6 hard to start.replaced coils sparkplugs . check relays and they check ok put new crank senser in still wont start. no dash lights work and there no fuel pressure on rail.and the motor cranks good and...
I think you've identified your own problem. In your description of the problem, you indicate "no fuel pressure on rail".....
First things first, try replacing the fuel filter. If this doesn't do the trick, make sure the fuel pump is actually pumping (you indicated that you hot wired it with a 12 volt DC supply and it ran). Running is one thing....pumping fuel another. To properly identify issue you need to know the cranking fuel pump pressure. If you can get it to start it would also be a very good idea to check out the fuel pressure regulator.
When you turn the key to the "ON" position (don't crank it, just to to the position where it would run) do you hear a few seconds worth of pump motor activity?
If it tried to start when you introduced fuel into the breather, then I think it's safe to say you have some sort of fuel delivery issue.
Jan 30, 2011 | 1999 Chevrolet Malibu
Does the table top bush dishwasher need to be on a table top for gravity drainage or can it be in a cupboard?
no it can be in a cupboard it does have a drian pump a small one which will pump up to 3 feet from the base of the machine,cupboard installation work fine on these appliances.
Nov 01, 2010 | Dishwashers
I have a Watermill SS45DLV shower pump which has stopped working. Tested fuse (ok) . Tested power to transformer (ok) but not sure what voltage i should get at the pump pcb as it's not listed on the rating...
38v AC I think, similar problem here, check you have a circuit on the primary side of the transformer! If it's open you need a new transformer.
Oct 29, 2010 | Heating & Cooling
2003 sprinter not getting fuel. Checked fuel pump fuse OK. Replaced fuel filter and purged lines with a vaccum pump. still will not start. I was driving the vehicle and came off the highway, stoped at a...
Quick safe way to check fuel pump. Put key in and turn to ON position listen for the pump to buzz or hum. Don't hear it its either the relay, pump or circuitry.
There are other tests but too envolved and dangerous to do. Bring vehicle to repair shop if you don't hear pump buzz. If it Buzzes them problem is either with spark or air.
need spark tester to test for spark. Do visual inspection on air intake plentium (no wholes, leaks) make sure mass airflow sensor is a-ok.
Apr 17, 2010 | Dodge Sprinter Cargo Cars & Trucks
'94 S 10 Blazer V6 Vortec EFI. Fuel pressure good, new fuel injectors installed, fuel pump works ok. Only starts with starter fluid sprayed into air intake. Any Suggestions?
your statement is fuel pump work ok, have you tested for proper fuel pressure. just because the fuel pump works it could have less pressure needed to start the engine. maybe the fuel filter is plugged. start out by replacing the fuel filter, if this doesn't fix it, you need to pressure test the pump. even 10 psi reduction in pressure will allow the engine not to start.
Nov 03, 2009 | 1994 Chevrolet S-10 Blazer
1991 Honda Accord cranks but will not start
I think you should check the air filter or air intake. It seems like it's not gettin and air to start since when you spray the starting fluid it's runs but stop and it stalls. I think that it's the air supply for the car.
Jun 05, 2009 | 1991 Honda Accord
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
