Question about Car Audio & Video
Does my Sharp multiple cd player need a tuner to function?
Coby cd troubleshooting
Coby outta business - bankruptcy. Cannot get parts so ..............
Jul 31, 2016 | Coby CX-CD377BLK Micro CD Player Stereo...
I have a 51 sony cd ..what else do I need?
Yes, Sandra, you need to plug this CD player into a tuner. Almost any tuner will work. Using a red & white audio cord (and any cords with similar plugs), connect the Line Out from the CD player to the Line In on the tuner. Depending on the tuner, you may have Line In inputs for CD player, AUX, and possibly others. Any of them should work.
If you don't have a manual for the player, you can download one from the Sony support web site at :
50 Disc CD Changer
Jun 12, 2014 | Sony CDP-CX53 51-Disc CD Changer
That's a receiver only, so its only built in function is the tuner. You'll need a separate CD player, plugged into the CD input jacks on the receiver's rear panel.
Jan 01, 2011 | NAD T763 Receiver
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
Need to use Aux function with Satellite Tuner installed.
Yes, you will need to consult your owners manual (if you don't have one try Kenwoods website). AUX functions are turned ON during initial setup (like when you set the time).
Mar 13, 2009 | Kenwood KDC-MPV619 CD Player
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Aug 10, 2008 | Sony CDX-M610 CD Player
The normal source selections for this model when the SRC button is pressed are: TUNER, CD and STANDBY.
If there is no CD inside the tray, or if it is dirty, unreadable, inverted or damaged, then the CD source option will not display at all.
If the there is a known good CD placed properly inside the tray and the CD source will still not show as a source selection, you may need to RESET the unit. The reset button is near mid bottom. This will also erase all settings, memory and tuner presets.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 08, 2008 | Kenwood KDC-3027A CD Player
No video, only sound from tv tuner.
You need to plug the male yellow wire into one of the female wires that says media control...... something along those lines..... youll figure it out
Oct 06, 2006 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
