Question about Kenmore Refrigerators
I have a new Kenmore Elite 106.5171 refrigerator. Huge amounts of frost have accumulated in the freezer. Please help.
  • Kenmore Master
  • 3,752 Answers
Turn off power let ice melt.
then turn on freezer again
if it happens again ring kenmore as it is most likely got a warranty and may have a faulty transducer or a faulty timer that controls defrost cycle .
or a local authorized kenmore warranty repairer . may be on kenmore website.
Posted on Dec 28, 2016
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
woodchuck789
  • 4070 Answers
SOURCE: My Kenmore refrigerator coldspot #70192001 is not
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
Frost accumulating in Kenmore Elite Grab-n-Go bottom freezer
Need to replace high limit switch. Call technician
Oct 13, 2014 | Kenmore Refrigerators
Why is there frost and ice in my freezer
If this is a frost free unit they actually have an internal heater. If you block the outlet for the cooling air in the freezer the heater cannot sense the dew point temp so it will not activate. Ice accumulates at the dew point temperature. Make sure the outlet isn't blocked. My wife blocks it all the time despite my many warnings not to. It's easier for me to rearrange things than keep repeating myself.
Aug 23, 2014 | Kenmore Elite 78722 78729 Bottom Freezer...
Frost buildup in freezer
this unit is under warranty if it is 3 months old you may have a defective defrost timer staying too long call for warranty.
Dec 11, 2013 | Kenmore Refrigerators
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Kenmore elite frost free is frosting over
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator was making a 'Thump'' noise every so often and just stopped working. Freezer is still working It's a kenmore elite 3 door bottom freezer refrigerator model number 76539
Unplugging for an hour won't allow it to defrost if that is what the problem is.
Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
Dec 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works but fridge does not cool..please help
Ther are several things that can cause this, one a bad evaparator fan or an defrost problem. Look on the back of the freezer wall and see if there is a lot of frost. If there is then it's a defrost problem and the part most likely is a bad termination thermostat also known as a bi-metal. If there is not a lot of frost, check to see that you have air going to the refrigerator section. If not then it could be the fan.
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer problem (icing behind cover inside of freezer)
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
