Question about Dewalt Drills
DeWalt dw935 saw the charger says fully charged but saw barley runs.
    Top Expert:
  • Dewalt Master
  • 77,939 Answers
The battery is defective.
Posted on Dec 15, 2016
Charger light blinks rapidly for dewalt charger?
usually indicates battery has failed slow blink charging steady red fully charged
Nov 03, 2017 | Dewalt Drills
Radio will not charge a battery but it will run off a fully charged battery
There is a charger module in the radio that may be bad. The module is well over $100, so maybe charging the battery in a seperate charger is the way to go.
Go here:
Choose the type that you have (Type 1 or 2)
On the parts diagram, the charger module is #43.
Good luck from Detroit, MI.
Oct 12, 2011 | Dewalt DC011 AM/FM Radio
When do you know the battery is fully chaarged
on the charger there is a red LED that blinks while it is charging when it is fully charged it will not blink usually about 1 hour to charge a DeWalt 18v battery
Jul 04, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I have just brought a new dewalt dc390 cordless circular saw and it seems that the motor is running backwards?
It is possible that the motor is running backward but... first see the manual here: Make sure the blade is installed as pictured in figure 4 page 11 of the manual.
After seeing the manual..... make sure the battery is charged correctly. The flat side of the battery should be toward the back of the charger when charging. If somehow the battery was inserted backward in the charger it is possible the battery was reverse charged during the intital charge. If you suspect this has happened.... insert the battery in the saw and run the saw until the battery is DEAD. Then insert it properly in the charger and leave it there for 9 hours so the charger will do the automatic tune up equalization of the battery.
If none of the above correct the problem, someone connected the internal battery power wiring incorrectly during FACTORY assembly. I would take it back to the retailer first... before processing a warranty claim.
You can contact DEWALT here:
call 1-800-4-DEWALT
Thanks for choosing FixYa,
Apr 30, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
DEWALT DW938 18VOLT CORDLESS SAWZALL can it use Lithium Batteries
As long as the voltage of the battery is the same as the tool, the tool won't mind if the power is coming from a NiCd or lithium battery. You do have to have a charger that works with lithium batteries to charge them up. Chargers that can charge lithium batteries can also charge NiCd and NMH batteies. NiCd chargers are not always programmed to detect when lithium batteries are full and may continue to charge them to the point of melting or starting on fire.
Jan 31, 2011 | Dewalt Dw938 18v Cordless Reciprocating...
Dewalt charger dw9116 got wet while charging and won't charge any more
let dry completely . if any corrosion on pcb clean with contact cleaner from radio shack
Jun 14, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Charger blinks while charging, stops when batteries are fully charged.
New batteries may not be charged from factory. Let them charge overnite and see if it stops blinking.
Feb 05, 2010 | Dewalt Drills
When charging battery flashes red then stays on long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt batteries
There are typically two to three contacts on battery packs. One to charge the battery, one to 120v (household) ground, and in the case of the third contact, grounding the battery pack.
Jan 21, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Drills Logo
78 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
