Question about Lands Phones
The handset does not ring when one makes a call and no calls come through
  • kakima Dec 15, 2016
    Hi christ0pher nkabinde, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • Brett Duxbury
    Brett Duxbury Dec 15, 2016
    is it a land line or something else ?
whosale
  • 24 Answers
SOURCE: Panasonic KX-TG5632 one handset high pitched constant ringing
you are getting feed back because of too high of a level. Turn your volume down on that handset and the squealing should go away
Posted on Dec 29, 2008
SOURCE: Base station on SPP-N1000 rings
Ok IF you can answer the Call and it still continues to ring, then this is a real wired problem, Usually, the "Ring" cycle, is used to "Trigger" a "Alerting" circuit that then makes a sound, when the call is answered, this "Resets" this circuit. Now IF it does continues, to ring AFTER the handset has answered the call as normal, then obviously, either the handset, is sending the correct signal back to the base, and the base is putting the call through, BUT the Ring Circuit, isn't being Reset. The fault, then must be with the base. You will have to get it looked at. As an aside, when does it stop, I mean it must, or that would have been your query too? No? So I assume, that it does eventually, stop, I expect it would, as usually, you would design in a "Watch Dog" circuit, that would, time out, if the circuit, didn't reset itself after a pre-defined period. So, Thats the Diagnosis, you will have to repair or replace. As usual though, remove from power, reset as if new, if still faulty. You know what to do.
Posted on Apr 16, 2010
  • 225 Answers
SOURCE: will not ring when getting
On the base unit there is a dnd button, try pressing to turn off Do Not Disturb.
Posted on Jan 22, 2011
caninnova
  • 9 Answers
SOURCE: handst flashes no messages
when the phone gets moist, and the vibreator gets overued then the button could be sticky and maybe ****
Posted on Apr 17, 2012
  • 135 Answers
SOURCE: the information on handset says 'the line is busy' unable to make or receive calls , when i call the phone it just gives ringing tone
The fact that it just rings when you call it indicates your line is open, which could be a wiring issue at a modular jack, or the modular cord between the jack and the phone, if it isn't just that it came unplugged.
I keep an old touch tone phone handy to act as a test phone to rule out a failed phone. With today's network terminations a customer can access a test jack outside your home/premise to test the line provided by the phone company before it heads inside to your phone wiring. If the phone works there at that modular jack, the issue is inside, if it doesn't, the issue is with the line to the phone company.
Once you narrow it down to inside wiring you can inspect any or all modular jacks to make sure the red & green wires are not broken at the screw terminals and that the modular jack wires are indeed firmly tightened to the same color wire terminal screw.
And last, another phone on the same line that is off-line or not hung up could cause the phone company equipment to isolate your line until the phones are hung up for a period of time to restore the line. So check that all phones are hung up, even cordless ones associated with the base on that particular line.
Posted on Jan 23, 2016
Handset is not ringing. Checked to make sure ringer and volume is on. What else could be the problem.
I assumed you are talking about your wireless phone.
Are you worried about handset ringing or the incoming call ring?
1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone.
Hope this helps. Best regards.
Sep 01, 2015 | Lands Phones
Handsets don't ring?
I assumed you are talking about your wireless phone. Are you worried about handset ringing or the incoming call ring? 1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone. Hope this helps. Best regards.
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
Base station on SPP-N1000 rings in steady tone when call comes in and continues ringing after handset is answered. Handset rings normally. How do I fix?
Apr 16, 2010 | Sony SPP N1000 Cordless Phone
How do I make internal calls to another Panasonic KG-TGA711E handset in the house?
Making an intercom call
1 Press {INTERCOM}
2 Select the handset you want to page
by pressing the desired handset
number ({1} – {6}).
To stop paging, press {OFF}.
3 When you finish talking, press
{OFF}.
Answering an intercom call
1 Press {handset icon} or {speaker icon} to answer the
page.
2 When you finish talking, press
{OFF}.
Note:
When the ringer volume is set to off,
the handset rings at the low level for
the intercom calls.
Feb 20, 2010 | Panasonic (KX-TG1032S) Phone
Ringing problem
I assume it does not ring but just beeps to let you know another line is ringing in case you want to put the current call on hold and answer it. It's called Off-Hook Call Announce, you want to have that option turned off on your extension or possibly the entire system. Do you have someone at your location that makes programming changes to the system or do you pay a company for that?
Aug 22, 2007 | Toshiba DKT-2020 Corded Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
