Question about Crafts & Hobbies
Christmas train engine drag's on tracks. The rear where the batteries are contained. Won't pull all the cars because of the dragging.
SOURCE: Persistent drag
If you're connecting it using the USB connector, try switching to the PS2 one.  I had various wierd problems with the standard MS USB HID driver with this device.  The standard MS PS2 driver works reliably.
Posted on Jan 31, 2008
  • 115 Answers
SOURCE: I KNOW HOW TO ADJUST
the rear wheels are made stationary they can not be adjusted sorry!!!!
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: engine drags while trying to start
It may be a problem with the camshaft-compression release. Some of the Briggs & Stratton models had a weak spring on the compression release whis is parts of the camshaft. you may also want tocheck that all wires are clean and tight. Also if it's a over head valve model check the valve clearance.
Posted on Jan 26, 2009
  • 347 Answers
SOURCE: Rear brake pad dragging
ADJUST THE BRAKE CLEARANCE ON ALL FOUR WHEELS.
Posted on Jan 01, 2010
  • 5 Answers
SOURCE: remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
Posted on Mar 08, 2010
MOTORCYCLE will not go over 50 mph or it bogs
iIf it is not fuel system, not fuel / air balance might be ignition system or wear and tear in the engine itself. Assuming the brakes are set up correctly and not dragging. Is the ignition timing correct. Is the compression okay? Cylinder head condition. spark leads good? Sounds like a trained mechanic with some diagnostic equipment might help you track the problem down.
Good Luck with it
May 30, 2015 | 2000 Suzuki VZ 800 Marauder
Lionel 6-30218 not working,The engine is making hissing sound the headlight bulb is glowing the cab cars have light ,The remote Red Light is glowing when turnig the knob of throttle to right & lef
Your best option is to contact Lionel Customer service:
598-949-4100 ext. 2
9AM - 5PM Eastern Time Zone
They will give you instructions if they think it needs to be sent in for repair.
Jun 02, 2014 | Lionel A Christmas Story Gauge Train Set...
Lionel g gauge wont run on track
I think you have solved the problem. Check all the wheels to be sure that they all turn. The locomotive isn't powerful enough to drag a car with a stuck wheel.
Dec 25, 2013 | Lionel Trains Holiday Express G Gauge...
04 jeep grand cherokee won't start just drags,
Could be a failing starter or problems with the cables.
A dead cell in the battery will do it too.
Jul 03, 2012 | Cars & Trucks
Replaced the rear brake pads and 1 side is dragging. i adjusted them and cannot adjust any more and still drags and makes noise?
Pull the drum off and check that side again. Maybe a shoe is slightly off track (not positioned properly, or a spring in the wrong hole, something like that). Compare both sides to see that all is correct. Check your emergency brake for proper positioning, too.
Self-adjusting? You did reverse, brake, reverse, brake to set the self-adjusters, right?
Good luck.
Nov 27, 2011 | 1997 Geo Prizm
Has trouble taking off.low exhaust pressure, low fuel mileage
Suspects will include air supply, compression, and exhaust.
After ruling out the obvious basics (fresh air filter, unobstructed air intake) pull the wire clip to the auto-choke and idle for a few seconds before dropping it in gear to check for a change in power.
*Have you pulled the rear wheels to check for a binding E-brake or broken springs in the drums?
What feels like a left-front drag could also be a rear dragging...
*Has it been smoking lately?
Apr 01, 2010 | 1994 Pontiac Grand Prix
Locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Dec 12, 2009 | New Bright 181 Toy Christmas Train
New Bright Model #183 - how do I make the train go? The light works when the engine switch is in forward and reverse, but the train doesn't move (wheels do not turn). The music plays from the coal are -...
Nov 27, 2009 | New Bright 181 Toy Christmas Train
I bought a new brighton toy christmas train set at a garage sale. the jert told me it worked. the music will play and the engine head light comes on but the engine will not run. are there replacement...
If says 187 on the box, check out this solution:
May 17, 2009 | New Bright 181 Toy Christmas Train
Crafts & Hobbies Logo
108 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
