Question about Coffee Makers & Espresso Machines
I have an Espresso Point. My power button blinks all the time and coffee is just spraying out everywhere. Any ideas what the problem is?
SOURCE: Blinking light
SCALE REMOVAL
The scale contained in the water, over time, will
cause plugging up of some elements in the appliance
and will thereby compromise its correct functioning.
The result will be that more time is
required to make coffee. The formation of scale
depends on the hardness of the water and on how
much the coffee maker has been used. To achieve
the best performance, descaling must be carried
out every so often. The coffee maker has a built-in
system that counts the number of cups of coffee
that have been made. The ON DRIP pilot light will
begin to blink when it is time to carry out descaling.
To do so, proceed as follows:
• remove the anti-chlorine filter (if present) and the
permanent filter from the coffee maker (so as not
to bathe them with vinegar)
• Dissolve 2 dessert spoons (about 30 grams) of
citric acid (available in pharmacies) in the
water;
• Place the container on the heating plate;
• Press the DRIP/AUTO button twice, allow
the equivalent of two cups to percolate and then
turn off the appliance;
• Allow the solution to sit for an hour;
• Turn the appliance back on and allow the rest of
the solution to percolate;
• Rinse by allowing the coffee maker to operate
with only water at least three times (1 full container
each time).
• Press the PROG and DRIP/AUTO buttons
simultaneously to reset the counter to zero.
IMPORTANT: if the machine is left unconnected to
the electrical mains for over two months, before
using it again it is necessary to carry out the
process of scale removal as described in the preceding
section.
10
Posted on Jan 14, 2008
mirran
  • 515 Answers
SOURCE: My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Posted on Aug 23, 2008
SOURCE: Coffee spurting everywhere!
Unlike the other person offering a solution I have experienced this problem like you when making the first cup. I found that sending a blank shot of water through first does the trick before putting the coffee grounds on. Hope this helps.
Posted on Nov 01, 2008
EsWorld
  • 1618 Answers
SOURCE: The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Posted on Jul 15, 2009
  • 19 Answers
SOURCE: My Lavazza Espresso Point Capsule Machine dispenser dry!
Sounds like you need a pump contact me www.lavazzarepair.com
Posted on Nov 12, 2009
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Jun 15, 2015 | Gaggia Brera Coffee Maker
Is there a way to stop coffee from spraying?
There is a little part that sells on ebay for $2 that slides into the Keurig brewer lid and stops coffee from spraying from reusable K-cups. It works great and is guaranteed or money back. Here is the link:
http://www.ebay.com/itm/EASY-FIX-STOP-COFFEE-LEAKS-FROM-REUSEABLE-K-CUP-EKOBREW-SOLOFILL-CAFE-KEURIG-/271239290594?ssPageName=STRK:MESE:IT
Nov 14, 2011 | Keurig B70 Coffee Maker
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
Exploding filter holder
The discharge solenoid is not functioning properly or the tube is dirty, try backwashing the machine.
Jan 31, 2010 | Saeco Gran Crema Espresso Machine
I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
Jul 15, 2009 | Gaggia Baby Espresso Machine
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
