We have a majestic DVD series fireplace and there is cold air blowing (a lot) from the bottom and top of our fireplace. It is very cold outside and this is just blowing in our house.
  • 15 Answers
SOURCE: unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Posted on Jul 28, 2009
  • 998 Answers
SOURCE: air conditioner blows air but dosen't cool house
clean outside fins and check freon level
Posted on Aug 17, 2009
  • 358 Answers
SOURCE: AC unit outside blowing out cold air, vents
If you have a heat pump probably there's a wrong connectionin the thermostat, but if is not a heat pump ,the compresor is not working or the unit leaked all the refrigerant.
Posted on Aug 30, 2009
Testimonial: "thank you, we have had a problem in the past with refrigerant leaking, was supposed to be fixed"
  • 674 Answers
SOURCE: cold air blows outside and hot air inside
Make sure it is in cooling mode. Sounds like you may have a problem with the reversing valve but you would want to check the pressures in the system first and make sure the charge isn't low.
Posted on May 02, 2010
  • 674 Answers
SOURCE: What's going on -- Vents are blowing hot air and
It sounds like the unit is stuck in the heat mode or the thermostat switch is still on heat. If the switch is in cool then you can go to the outside unit and locate the reversing valve. It may be stuck in the heat position. You can tap it with the handle of a screwdriver but only on the ends and very lightly because if you dent it the valve will be stuck for sure. If it shifts you will hear a loud hiss as the pressure equalizes. You could also try unplugging it from the circuit board. On some units it is energized in the cool mode and on others it is energized in the heat mode.
Posted on Jun 06, 2010
I bought an Insta Flame model FSDV 30 direct vent wall furnace, need a natural gas conversion kit. It currently is set up for propane and could use some help in finding the parts and installing them.
There is a ban on that particular furnace as they can explode!
You won't find parts or anyone that will work on it.
[PDF]TSSA Bans Series of Insta-Flame and Northern Flame Fireplaces
  1. Cached
  2. Similar
Oct 23, 2012 - (TSSA) has banned a series of natural gas and propane-fired direct vent ... 'FSDV22' or 'FSDV30' or 'FSDV32' in the model name or number.
TSSA Bans Series of Insta-Flame and Northern Flame ... - CNW Group
  1. Cached
  2. Similar
Oct 23, 2012 - All Insta-Flame and Northern Flame natural gas or propane-fired direct vent freestanding fireplaces with 'FSDV22' or 'FSDV30' or 'FSDV32' in ...
[PDF]Fuels Safety Program DIRECTOR'S ORDER - TSSA
  1. Cached
  2. Similar
Mar 25, 2016 - Natural Gas Fired Direct Vent Free Standing Fireplace - Model ... Insta-flame or Northern Flame: Models FSDV22, FSDV30, FSDV32, D222.
Majestic Fireplace - - Recalls & alerts - Healthy Canadians Website
  1. Cached
  2. Similar
Nov 9, 2012 - Natural gas and propane-fired direct vent free-standing fireplaces ... Insta-flame or Northern Flame (Models FSDV22, FSDV30 and FSDV32, ...
TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32
  1. Cached
  2. Similar
Dec 21, 2012 - TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32 ... CFM Inc. (Majestic Fireplace) and bear the trade names Insta-Flame or Northern Flame ... (a) Natural Gas Fired Direct Vent Free Standing Fireplace - Model FSDV22, FSDV30 ... -Stove shipped as natural gas; LP Conversion Kit included
Dec 11, 2016 | Kitchen Ranges
Wind blows out the gas logs
I am sorry, but there is insufficient information to give a proper answer. If it is a vented logset, is it in a vented indoor firebox/fireplace or an outdoor fireplace?
Jan 11, 2016 | Majestic Fireplaces Majestic VWF24NMD 24"...
Fan kit will not fit into sequoia opening
You will need to cut back the mortar from the front so you can install the fan kit. If you want to try and do it yourself you will need a masonry blade (diamond blade) on a skill saw and set your thickness on your skill saw to very thin so you don't cut into the fireplace.
Other option is to get a chisel, depending on how much overlaps onto the face, and chip it all back.
You are correct that if you do not get the mortar off of the front to where you can open the front you will not be able to install the fan kit. You can pull up this installation manual at this website
Good luck. Vermont Castings
Jan 11, 2014 | Majestic Fireplaces Majestic FK26 Blower...
We are in need of a heat exchanger for our 1979 Majestic heatilator fireplace. The size is approximately 19"X19". Where can we purchase this item?
Unfortunately, any replacement parts for a 1979 Majestic Fireplace are long gone. Majestic went bankrupt 4 or 5 years ago.
Sorry, I wish I had better news. But, it is what it is. Thanks for choosing FixYa.
Sep 21, 2011 | Heating & Cooling
When we built our home 6 years ago, Airtron installed a Majestic NVBR36RN vented fireplace system. We had to turn our gas off a while back and never thought about the fireplace until now when we wanted to...
It has a panel hidden under the white fiber hearth bricks at the front bottom of the unit. you need to clean the lava rock off of them, pull both of them up, and then you will see the hidden linear cover that allows you to access the valve and light.
Dec 02, 2010 | Heating & Cooling
We a have a majestic fireplace Model# FS32RN Serial # S31A0096211021 Can we put it into a corner and if so what would the clearance be for it??
Interesting. I just bought a Majestic Fireplace. The data plate is missing, but there is a tag on it that seems to indicate it is a FS 32RN. There are several Majestic units that have been red flaged as the glass blows out. Would be interested in seeing a pic of the one you have to see if it is the same as mine.
Nov 08, 2010 | Heating & Cooling
Gas logs while turned on seem to fade, nearly go
you must keep the burner and the pilot light area clean and free of dust also,the area where your burner gets air most of the time it has an adjustment to give it more or less air.I have had my dyna glo vent free model for 8 years.A good cleaning in late fall with low pressure air and 1 or 2 times through the winter depending on conditions of use.
Jan 07, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
