Question about Retail Supplies
I have a brandt coin sorter and counter model 957, it has worked well, but encountered a problem with it not registering a count for quarters only. All other coins register. Suggestions?
I have a Brandt 1200 series coin counter that won't turn on. The display works, just won't start. Does anyone have a service manual or solution to the problem?
I work for the former Brandt company, now called Glory.
Let me be clear on this. The Brandt/Glory company makes the best counters on the planet. That being said the model 1200 is the worst design ever. I never liked it and it's been last made 25 years ago.
Lets start simple. In the back of the machine there are 2 fuses. F1 protects the motor and is a 3 amp fuse. F2 is a 1/2 amp fuse to protect the display. Make sure they are good.
Next you'll have to take the back off to see if the belt is broke or the pulley fell off. Or, the motor plug has come loose?
Do a machine reset by unpluging the power cord. Then while pressing and holding the "C" key, plug the machine back in and wait 5 seconds. If the above does not help at all, you have more serious problems like bad motor, bad motor controller.
You can try calling me at nine8five 8ninethree 5two4one
Good luck
Jun 10, 2015 | Retail Supplies
How to save setting on brandt 8672
The 8672 is a terrific machine. Once you change any setting it will automatically save it as the new default setting when powered up.
Oct 12, 2014 | Brandt 8672 Note Counter
FS-4DA coin sorter won't count pennies
The good news is that the unit is functioning, it's just counting pennies. I had the same problem with quarters and is a fairly easy fix. I won't get into any disassembly details, but you'll need to gain access to the infrared detectors (mounted to the motor assembly) and possibly the emitters (mounted to the front panel LCD display/push button board). Also, please be careful not the damage the wire harnesses when removing the top cover. Once apart, you can use your cell phone camera (which is sensitive to infrared) to see a purplish/white glow from a healthy emitter. Compare the penny emitter to the others and chances are it will have a lower output level and need replacing. If the penny emitter is strong, then check the detector with any infrared remote control( TV, cable box...) by pointing the IR remote control towards the penny detector and pushing any of its control buttons. This should make the penny amount count up, and fast too, as the remote sends out IR pulses while a button is being pushed. If this test doesn't increment the penny count, then the penny detector needs replacing. But before you do, try this remote control test on another known good detector to verify your findings. Please keep in mind that other malfunctions besides an emitter and detector could be the cause of your problem, but given the FS-4DA circuitry, the odds are extremely high that you have a bad emitter 1st, then a detector 2nd, as emitters are known to degrade over time and especially when continuously powered, as in the case of a switched 'ON' FS-4DA. FYI...IR emitters and detectors can be purchased from Radio Shack. Good luck and take care not to electrocute yourself when powering the unit with its cover removed.
Feb 21, 2014 | Royal Sovereign Fs 4DA Model Fs 4DA Coin...
Brandt coin counter and sorter, looking for a manual for it, not sure of model, have a pic of it
No one can give you a manual with out a model number! There are hundreds of models. A picture would be helpful.
Call me, I may have one if I can "see" the machine.
Harry 985 / 893-52four one
Nov 11, 2013 | Retail Supplies
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
What is the maximum amount of bills a bill counter can count?
From what I have read, it seems that what matters the most is the speed of the counter. In this article I found, the fastest counter can count 1500 bills per minute:
http://www.abcoffice.com/office-equipment-news/tag/bill-counter-reviews/
Apr 29, 2013 | Retail Supplies
Retail Supplies Logo
147 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
