Question about Toro Garden
Key doesnt turn
Tried to turn the key this morning, the engine ran but the blades would not move.........what to do? Toro Power Curve 1800 electric
  • Toro Master
  • 7,515 Answers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on Mar 22, 2017
5 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(, to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Posted on Jun 09, 2009
SOURCE: Toro Blower..No power. Like a blown fuse. Does it have a fuse?
I have the Toro 51591 model. Yesterday, mine did the same as yours. I opened up the case and found that a small cylinder had broken off of the switch. So it could be that your switch is the problem. I have been unable so far to find a replacement anywhere.
You should consider using your warranty.
Posted on Dec 12, 2009
Testimonial: "Thanks. I checked the manual first though and read that the impeller cover if not properly closed will not allow it to turn on. That worked. Thanks"
  • 54 Answers
SOURCE: toro 1991 42 inch mower doesnt cut even how do i
The blades should be a simple bolt on, how ever there are no adjustments at the blade. Your adjustments are on the swing brackets that raise and lower the deck.
Posted on Apr 28, 2010
  • 31 Answers
SOURCE: cannot start Toro 1800 snowblower (electric)
Can you pull start it? If so,you may need a new starter gear,about $30,they're plastic & wear out.
Posted on Jan 12, 2011
Working on a Toro Timecutter 5060. Machine will start, mower blades will run, but the machine won't move when the motion control levers are pushed forward
sounds like the switch wiring is compromised and possible that the hydraulics are in the disengaged setting. i wouldn't recommend messing with the electrical. most small engine shops offer inexpensive if not free estimates to repair these kinds of issues.
Apr 15, 2016 | Toro Garden
adjust the cable at the bottom will work again
Mar 05, 2013 | Toro 1800 Power Curve
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
Toro 1991 42 inch mower doesnt cut even how do i
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
How to change my rotor blade on my toro
Is there an easy way to install rotor blades on a Toro Model 38430 snowthrower?
Mar 03, 2010 | Toro Garden
I have the Toro edger/trimmer combo - which way does the edger blade bolt turn - I tried counter-clock-wise it won't budge. Also how to the LOCK the blade from turning??
on blad removal the nut goes opposite to tighten, lefty tighty, righty loosen. Put a metal wrench or rod in between the blade and the guard to keep the blade from moving.
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro electric start won't start manually
If it doesnt start manually,you have another issue to deal with. Whether it has electric start or not you should be able to manually pull start it. You can also get the model and serial number off the engine and contact your nearest toro dealer to have charger and key ordered. As far as a push button,it can be done,just a matter of finding someone to install one for you.
Jun 03, 2009 | Toro Lawn Mower With Toro Power Tools
I was blowing snow with my Toro Power Curve 1800. I was distracted for a moment and tangled the cord in the blade. The cord is wraped around tight, how can I remove the cord?
unless you are able to turn the blade backward and pull on the cord at the same time no luck. it may be easier to just cut the cord and install a new one. solution one is best and both require taking the machine apart. start there and hope it works out for you.
Ps. dont forget to rate the solution. Thanks
Dec 28, 2008 | Vacuums
Garden Logo
151 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
