What to do if c is x+ in pythagoras theorem - Office Equipment & Supplies
  • 620 Answers
Let me know if I answer your question.
a^2 + b^2 = c^2
If you are given a and c and have to solve for b, let's do it this way.
5^2 + b^2 = 13^2
25 + b^2 = 169
25 + b^2 -25 = 169 - 25
b^2 = 144
b = sqrt(144)
b = 12.
I hope this helps.
Good luck.
p.s. Here is a great video of Pythagorean Theorem in water;)
Pythagorean theorem water demo
Posted on Dec 17, 2016
The diagonal of rhombus are 8 cm and 6 cm then the length of each side of the rhombus
Lesson HOW TO solve problems on the rhombus sides and ... > Geometry > Customizable Word Problem Solvers
  1. Cached
Lesson HOW TO solve problems on the rhombus sides and diagonals measures - Examples ... Find the perimeter of the rhombus, if its side is 7 cm long. ... Since all four sides of the rhombus have the same length, the measure of the side ... 32/4 cm = 8 cm. ... In our case the legs are 12/2 cm = 6 cm and 16/2 cm = 8 cm long.
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm ... > Geometry > Customizable Word Problem Solvers
  1. Cached
  2. Similar
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm. What is the ... (paid link). Click here to see ALL problems on Geometry Word Problems ... We need to find the side of the rhombus using the Pythagorean Theorem. After that, we use ...
The diagonals of a rhombus are of lengths 6 cm and 8 cm. Find the ...
  1. Cached
  2. Similar
Jun 29, 2013 - The diagonals of a rhombus are of lengths 6 cm and 8 cm. ... rough aketch and you will see that in each triangle the shorter sides are 3 cm and 4 cm, so using the Theorem of Pythagoras, if we call the hypotenuse l cm, then l^2 ... Rhombus
Mar 30, 2016 | Office Equipment & Supplies
Using the Pythagoran Theorem , find the length of a leg of a right triangle if the other leg is 8 feet long and the hypotenuse is 10 feet long . Q
10 x 10 = 100
8 x 8 = 64
x = sqroot (100-64)
x = sqroot (36)
x = 6 feet
the square of the hypotenuse equals the square of the adjacent + Square of the opposite.
So H^2 = O^2 + A^2
the convention is C^2 = A ^2 + B^2
square root of any of the components gives the actual value
but the addition or subtraction has to be the square of the values
Feb 07, 2015 | Office Equipment & Supplies
A right angle triangle with length of AB 10cm and AC 20cm, how do I find the angle of BC
Assuming that the angle at A is the right angle, Pythagoras' theorem says that the length of the hypotenuse (the side opposite the right angle) is the square root of the sum of the squares of the other two sides. In your case, AB and AC are 'the other two sides' and BC is the hypotenuse, so:
/ 2 2 /
length BC = V 10 + 20 = V 100 + 400
= V 500 = 22.36 cm
(To find the angle at C, you need trigonometry and is arc-tan(10/20)
and the angle at B is arc-tan(20/10) - 26.5 deg and 63.5 deg)
Oct 17, 2014 | Computers & Internet
Calculate hypotenuse
"Hypotenuse" implies a right angle triangle is wanted here. With Pythagoras' Theorem it is always good to look first for a 3-4-5 pattern, the simplest ratio, although a right angle triangle easily can be other ratios too.
24 x 32 is (3 x 8) x (4 x 8) so it is a 3-4-5 triangle after all, and the hypotenuse is then 5 x 8 = 40
Or, you could calculate SQRT (24^2 + 32^2) = 40
Aug 12, 2014 | Computers & Internet
If a square with sides of 14 inches is inscribed in a circle what is the diameter of a circle
It is the diagonal of a square 14" on a side. So by Pythagoras' Theorem
D^ = s^2 + s^2 = 392
D = 19.8"
Mar 28, 2014 | Mcgraw-Hill Computers & Internet
Two forces of 5 N and 12 N respectively act on the same point. show how you would determine the magnitude of the resultant by using the tail-to-head and tail-to-tail methods and pythagoras theromen (13 N)
Draw a vector of length five. From the head of it, draw another vector of length twelve. Now measure the distance from the tail of the first vector to the head of the second.
If the two vectors are at right angles then Pythagoras' theorem applies. Square five to get 25. Square twelve to get 144. Add them to get 169. Take the square root to get 13.
Jan 24, 2014 | USAF Security Forces Shield Decal
in building terms there is the 3, 4, 5 rule, which allows you to determine a perfect right angle. This is from the Pythagoras theorem which says - the square on the hypotenuse equals the sum of the squares on the other two sides.... so to calculate the hypotenuse we square 3 and 4 to get 9 and 16 respectively. Adding these give 25. Getting the square root of 25 gives 5 which is the dimension of the hypotenuse...
Any combination of 3/4/5 works - so 6/8/10 is also valid.
Hope this helps.
Oct 22, 2013 | Measuring Tools & Sensors
The ads for this device state that it uses the Pythagorean theorem to figure the distance of a 3rd side, if you can measure the other 2 sides. I How do I use this feature?
1) There is a big difference between Bosch promo manual and Bosch operation manual:
2) Online promo manual says: Combined Indirect/Pythagoras for measuring total height from a distance
3) Online operation manual shows no instructions for Pythagoras measuring.
And shows no button for displaying E value or height.
4) Operation manual shows:
Length Measurement** and tells you to measure the height while promo says tool will calculate height E
Area Measurement*** shows rectangle only and not triangle
Volume Measurement
Area or Volume
Rounding of Large Calculations
Continuous Measurement (Tracking)
5) I would contact Bosch directly:
6) Until you get satisfaction from Bosch, the Bosch device gives precise menasurements that can be entered into a Pythagorean calculator online, which defeats the purpose of a jobsite tool: But you can access online calculator via cell phone while on jobsite.
Feb 19, 2011 | Bosch DLR130K Laser Distance Measurer
Pythagorean theorem to find the width along the horizonal
You should checkout Bitesize revision:
To summarise - Pythagoras works with right angled triangles only (with one 90 degree angle). One side is always bigger than the other two - it's always the one opposite the 90 degrees.
The long side (hypotenuse) times by itself is the same as if you times-ed the other sides by themselves and added them together.
In your question, you're trying to find the across (which you guess as 12?).
The diagonal (14) is opposite the right angle so it's the biggest (and equal to the other two). We'll call across a, we don't know what it is.
14 * 14 = (7.5 * 7.5) + (a * a)
(14 * 14) - (7.5 * 7.5) = (a * a)
Type that bit on the left into a calculator (you might need to do it in parts - work out 14 * 14 and write it down...). Once you've got the answer you need to use the square root button to find out what a is.
May 06, 2009 | SoftMath Algebrator - Algebra Homework...
Trig and distance
this is solved by starting with the SECOND leg of the flight considered as a triangle.
Find how far DUE east the plane travels (100 km x Cos10 = 83.9 km) using 10 degrees because that is how much is left of the 90 degree quadrent after subtracting the 80 degrres course direction.
Similarly find out how far DUE north the plane travels (100 km x Cos80 = 11 km).
Now get the total flight NORTH = 300 + 11 = 311
- and total EAST = 83.9
Finally, use Pythagoras get the total DISTANCE:
square root of ( 311 squared + 83 squared ) = 321 km
Also the DIRECTION from its Tangent of 83 /311 = 14.9 degrees
Dec 19, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
42 people viewed this question
