Question about Friedland Home Security
Does anyone know how to wire a friedland E861 door bell? It has terminals 0 1 2 3 4.
I can wire a transformer to 3 & 4 and press to test button on the front of the bell to get it to work I don't know how to wire a door button to it!
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
SOURCE: New wired Heath/Zenith doorbell buzzes until disconnected
it sounds like you have a bad push button . if the wires where crossed you would most likely have this problem as soon as you turned on power .
Posted on Mar 17, 2009
SOURCE: dmc1cd doesnt work or door intercom with bell
I found the following generally showing where the wires are supposed to connect. Click here.
And this has a detailed wiring diagram.
Best of luck!
Posted on Jun 11, 2009
SOURCE: I have a desa TR-0081-BX
There is a little "diode" that should have been provided as part of the unit...it's a little wire with a B-B-sized circuit in the middle that has to be connected to the push-button at the door. This "extends" the circuit from the button to the chime unit for the full 8-notes. Hopefully you still have that part (I just about threw out mine before I read the instruction manual thoroughly. My diode just "shorted" after I power-washed my house...and I am in search of that particular part. I contacted Heath Zenith...hopefully they will give me a solution on how to get only that part. In any case, you need that diode to get the chime to play correctly.
Posted on Mar 27, 2011
Craftmade CA3-RC Artisan Door Chime
AC is likely to be the alternating current supply from the transformer.
I suspect two pairs of AC terminals are provided to allow one of two different chimes to be selected with one pair and the common being used for the 4 chime pattern and the other pair and common used for the 8 chime pattern.
The front, side and rear terminals are self explanatory connections from each bell-push with the supply (or return) or other wire from each bell push connected to the COM or common.
The manufacturer's website doesn't feature a wiring diagram though might send you an instruction book on demand. The site does include a note specifying only 18 gauge wire is to be used...
Dec 10, 2017 | AC Cars & Trucks
I am trying to install a Ring 2 Doorbell using the existing E851 Friedland Stockport 5K5 6BP chime. When I connect my wires the chimes ring continuously. What might I need to do?
Connect the new wire to the wire going to the original door bell button. one core of the new wire to one core of the existing wire and connect the other new wire core to the other existing wire core. insulate the joints from each other and any metal surfaces.
Aug 08, 2017 | The Home Security
I have an Edwards C210-W Economy Door Chime for my livingroom door. Wires came undone while painting and I don't know which wire goes where. Yellow wire coming out of the wall is from the transformer
They are connected to the chime terminal board with 3 connections!
1) wire from the transformer.
2) wire from 1st push button.
3) wire from 2nd push button.
Dec 29, 2015 | Cars & Trucks
Need lighted door bell button
Illuminated bell buttons were very popular in the old days of mains transformer driven standard door bells. The bell coil needed quite a lot of current to drive it and so connecting a small lamp across the button contacts did not affect the bell or button operation and allowed enough light to illuminate a small nameplate or just the button for easy location at night.
This allowed standard 2-core bell wire to perform both the function of bell operation and button illumination. For electronic type door bells it illumination of the bell button is needed either a 3 or 4 core cable would be needed or a separate lamp, something perhaps like a welcome home lamp that is operated by a pir.
Freidland was the principle manufacturer in the UK and is still a popular choice for quality equipment but I expect similar equipment was or is available all around the world.
Oct 16, 2015 | Home Security
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
Friedland Evo Wireless Door Chime and Push Problem
While this is a little bit of a stab, if you replace the batteries in both units, do it at the same time, If the batteries are known good ones, simply take them both out and let the units sit for about 5 minutes before you put them back in. Make sure the battery contacts are clean and devoid of corrosion. Put them back together without pressing the button. I assume it is of the newer "self learning" style. In which case, hold the ringer button down until the chiime goes off.
If it is one of the optical greeters, there would be a setup switch position that allows you to focus/align the reflector for the greeter. Usually it keeps chiming until the alignment is correct whereupon it shuts off when things are right. Then you reset the switch to normal. If no switch for set up at all- just follow the same procedure until it stops. You can usually "eyeball" them pretty close without effort.
Dec 30, 2011 | Home Security
Have had major snow storms in the past few weeks. Installed, prior to storms, new door chimes that worked. Since the storms, neither the front nor side bells function. The bell button has a light on...
Most times, doorbell problems are button, especially since indicator light shows you have power.
Take off front doorbell button and see two wires.
These wires are low voltage and safe to touch.
Use screwdriver and touch both screws together, or remove wires from button and then touch two wires together.
If doorbell rings, then replace button.
If bell still doesn't work then scratch two wires together and look for static-type spark that says wires have power.
If wires have power, and you crossed both wires and bell didn't work, then new door chime is suspect.
If wires do not have power, then transformer is suspect.
Open following link to see example transformer:
http://waterheatertimer.org/images/attic-transformer10.jpg
Transformers are located in basement or attic.
Scratch a wire across both screws on transformer and look for static-like spark.
If no power, then check circuit breaker.
Home centers sell transformers in the doorbell section. They are 12 and 24 volt. Check markings on old transformer.
If transformer has power, then new door chime is suspect.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Garden
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
Installation of wired doorbell
yes it is very simple. All you have to do is connect either the two red wires together or the two black wires together and put the other remaining two on the doorbell chime to the common and front terminals. Here is how it works. One red wire leaves the transformer. It connects to the other red wire going to the pushbutton. When you press the button the voltage comes back to the bell on the black. You have the other black from the transformer on the bell so that completes the circuit. The only reason I say to put either the two blacks or two reds together is that way you're sure to have one wire from the transformer and one from the doorbell. Not a 'pair" of wires from each. 5ec779c.jpg
Jul 11, 2010 | Hammering
Home Security Logo
313 people viewed this question
Top Friedland Home Security Experts
Lawrence Oravetz
Are you a Friedland Home Security Expert? Answer questions, earn points and help others
