Question about Barcalounger Oracle II Recliner with Stargo Red Top Grain Leather
Barcalounger Oracle II. Arm rest was loose.
Barca sent very specific tightening tools. Unfortunately, bolt has completely slipped out and down into chassis which appears impossible to access. Waiting Barca response. Any ideas?
How to fix arm of a BarcaLounger Oracle ii
turn it over and look under neath it might need larger screws if the wood is pulled out .
Dec 21, 2015 | BARCALOUNGER-RECLINERS Barcalounger Oracle...
Tip
Bottom Bracket & Spindle Replacement of LeMond RevMaster
Part 1 Video Discussing the Dis-assembly & Inspection of the Bottom Bracket & Spindle for a LeMond RevMaster Bike
  • This Part 1 video will demonstrate how to inspect and adjust or remove and replace the bottom bracket and spindle on your Lemond Revmaster
  • Tools needed for this procedure:
    • 8mm Allen Wrench or Socket
    • Cotterless Crank Puller Tool
    • Lock Ring Removal Tool
    • Bottom Bracket Tool
    • Phillips Screwdriver
    • 4mm Allen Wrench
    • Bungee (optional)
    • Rubber Mallet
    • 7/8" Wrench
  • To begin remove the belt cover, there are four screws
    • You will need a 4MM Allen wrench
  • Now remove the two screws on the back from the opposite side of the bike
    • You will need a Phillips screwdriver
  • Now position the crank arm as seen in the video and remove the belt cover from the bike
  • Before removing the drive belt, tighten the brake assembly so that the flywheel is locked in place and loosen the torque on both bolts using an 8mm Allen wrench or socket
    • Do not remove them at this time only loosen them by a half a turn or so
  • Using a 7/8" wrench loosen the belt idler
  • Now use a 4mm Allen wrench to loosen the tension adjustment bolt completely, but do not remove it from the frame
  • Now remove the drive belt
    • To aid in this process you can use a bungee to slide in behind the belt at the top, as shown in the video
  • Then pull away from the bike while spinning the crank arms
  • Now remove both crank bolts with a 8MM Allen wrench or socket
    • Removal of the crank bolt on the left side of the bike is the same as removal from the right side
  • Now remove the crank arms with a crank arm puller, threading the outer portion into the crank arm as shown in the video
    • Be sure to thread the outer portion in as far as possible to prevent damage to the crank arm threads or the tools threads
    • Use a 7/8" wrench to make sure the outer portion is threaded in completely
    • Now spin the handle clockwise to press the crank arm off of the bike
    • Be careful when the crank arm comes off as if you are not holding it, it can fall in the floor
    • Also use the wrench to loosen the tool before removing the crank arm from the unit
    • Now you can unthread the tool from the cranks arm by hand after removing the crank arm from the bike
  • Next inspect the bottom bracket cups for looseness, to do this use the bottom bracket tool by hand to see if you can turn either of the bearing cups
    • To further verify the adjustment of your bottom bracket use a rubber mallet to tap lightly on each side of the spindle to check for movement from side to side, if you have movement, or one or both of the bearing cups is loose, you need to re-adjust the bottom bracket. If you are only inspecting the bottom bracket and did not find any need for adjustment you would re-assemble the bike at this point
  • Once the crank arms are removed look closely at the spindle
    • It should have defined edges and be smooth
  • As you can see by the video our spindle needs to be replaced
  • Next you will need to remove the lock ring
    • The lock ring is around the bottom bracket cup on the left side of the bike
      • In the video is an example of a lock ring
    • To use the lock ring tool you slip it over the lock ring using the three notches and torque the lock ring in the proper direction
      • This one needs to be turned counter-clockwise to loosen
    • Then remove the lock ring by spinning it off the bearing cup
  • Next you will need to use the bottom bracket tool to remove the bottom bracket cups
    • Begin with the left side
      • Slip the tool into the splines of the cup and loosen
        • For stubborn bottom brackets use a 5/16"-24 x 2" bolt and some washers with a 1-1/4" wrench
          • Slip the tool into the splines and thread the bolt with the washers into the spindle
          • Get it snug but not completely tight
      • Now use the wrench to turn the cup counter-clockwise for the left side and remove it completely
    • Remove the cup from the right side now
      • Slip the bottom bracket tool into the splines of the cup and turn it clockwise to loosen
    • If you cannot get the cups loose with this method try turning the bike on its side to get better leverage as shown in the video
  • This concludes the dis-assembly and inspection procedure of the LeMond RevMaster bottom bracket & spindle
  • Click here to see Part 2, re-assembly and installation to complete the replacement procedure
Video of Bottom Bracket and Spindle Replacement Part 1 Dis assembly LeMond...
on Feb 19, 2015 | Lemond Revmaster Lemond G-Force Digital...
How do I tighten the arm rest bolt on a 2002 Toyota Sequoia?
Apply pressure on the interior nut by pulling the bolt towards you why carefully tightening.
Aug 28, 2014 | 2002 Toyota Sequoia
How do I tighten down arms?
I know it's late but Barca just sent me special tools that they expect returned. Unfortunately, the screw has completely fallen off into the closed chassis!
Sep 21, 2013 | BARCALOUNGER-RECLINERS Barcalounger Oracle...
The right side front passenger lower control bolt is slipping how to fix the loose bolt on 1997 cherovlet calaiver
if its the bolt that attaches to the spindle thats the lower ball joint u will need to jack up and support vehicle remove the wheel you will need to support control arm with a jack and decompress spring and chain or secure for safety reasons so it doesnt shoot out and cause injury cut or drill out the 4 rivets that hold the ball joint in place [if it is a pressed one will need to buy or a lot of auto stores will let you borrow a ball joint press]replace with new done ---if the bolt is the one attached to the frame need to do same set up and remove old and replace but the bushings are what will slow u down a bit while replacing
May 14, 2012 | Chevrolet Cavalier Cars & Trucks
What are the torque specifications for a 3.5l v6 1995 ford tarus rocker arm
For each valve, rotate the crankshaft until the valve lifter rests on the heel (base circle) of the camshaft lobe. Position the rocker arm(s) over the push rods, then install the rocker arm seats. Tighten the rocker arm seat retaining bolts to 44 inch lbs. (5 Nm).
Final-tighten the rocker arm retaining bolt(s) to 19-25 ft. lbs. (25-35 Nm). For final tightening, the camshaft may be in any position.
Hope helps.
May 19, 2011 | 1995 Ford Taurus
Upper and lower control arms need to replace how do i go about it
Upper Control Arm and Bushings–C-Series REMOVAL & INSTALLATION
  1. Raise and support the truck on jackstands. Fig. 1: Installing the upper control arm — C-Series 84908029.gif
  2. Support the lower control arm with a floor jack.
  3. Remove the wheel.
  4. Remove the air cleaner extension (if necessary).
  5. Unbolt the brake hose bracket from the control arm.
  6. Remove the cotter pin from the upper control arm ball stud and loosen the stud nut until the bottom surface of the nut is slightly below the end of the stud.
  7. Install a spring compressor on the coil spring for safety.
  8. Using a screw-type forcing tool, break loose the ball joint from the knuckle.
  9. Remove the nuts and bolts securing the control arm to the frame brackets.
  10. Tape the shims and spacers together and tag for proper reassembly. The 35 Series bushings are replaceable. The 15/25 Series bushings are welded in place. To install: Installation is the reverse of removal but please note the following important steps.
  11. Place the control arm in position and install the shims, bolts and new nuts. Both bolt heads must be inboard of the control arm brackets. Tighten the nuts finger tighten for now. NOTE: Do not tighten the bolts yet. The bolts must be torqued with the truck at its proper ride height.
  12. Install the ball stud nut. Tighten the nut to specification.
  13. Lower the truck. Once the weight of the truck is on the wheels:
    1. Lift the front bumper about 38mm and let it drop.
    2. Repeat this procedure 2 or 3 more times.
    3. Draw a line on the side of the lower control arm from the centerline of the control arm pivot shaft, dead level to the outer end of the control arm.
    4. Measure the distance between the lowest corner of the steering knuckle and the line on the control arm. Record the figure.
    5. Push down about 38mm on the front bumper and let it return. Repeat the procedure 2 or 3 more times.
    6. Re-measure the distance at the control arm.
    7. Determine the average of the 2 measurements. The average distance should be 95.0mm plus or minus 6mm.
    8. If the figure is correct, tighten the control arm pivot nuts to 88 ft. lbs. (120 Nm) on 1988–90 models; 140 ft. lbs. (190 Nm) on 1991–98 models.
    9. If the figure is not correct, tighten the pivot bolts to 88 ft. lbs. (120 Nm) on 1988–90 models; 140 ft. lbs. (190 Nm) on 1991–98 models and have the front end alignment corrected.
Aug 31, 2010 | 1993 Chevrolet C1500
Removal of front right axle from a jaguar 2002 x-type
Loosen the wheel hub nut.
Remove the front road wheel and tire.
Remove the tie rod end retaining nut.
Using the special tool 204-192 Ball joint Splitter
detach the tie rod end.
Remove the subframe reinforcement plate retaining bolts.
Loosen the subframe rear mount bolt.
Loosen the subframe front mount bolt.
Remove and discard the wheel hub nut.
using spcial tools 204-269Forcing Screw,205-491-01 adapter nuts,205-491 wheel hub puller
Detach the wheel knuckle.
Remove the lower arm ball joint retaining bolt.
Reposition the lower arm.
using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle
detach the halfshaft.
Remove the exhaust muffler inlet pipe.
Remove the halfshaft seal.
Remove the transfer case Y bracket retaining bolt.
To prevent damage to the transfer box internal seal,
make sure that the link shaft is not retracted further than
200 mm from the transfer box casing.
remove the halfshaft.
Attach special tools to the halfshaft.
Lever the special tools to displace the halfshaft.
Install the transfer case Y bracket retaining bolt.
Remove the halfshaft.
Use suitable protective covers to protect the barshaft.
Remove the halfshaft snap ring.
Install a new snap ring to the halfshaft.
Install a new halfshaft seal.
Remove the special tool.
Make sure the CV joint splines are located fully.
Do not use excessive force when engaging the CV joint into the link shaft.
Install the halfshaft.
Tighten to 25 Nm.
Attach the wheel knuckle.
Install the lower arm ball joint retaining bolt.
Tighten to 83 Nm.
Install the exhaust muffler inlet pipe.
Tighten the subframe front mount retaining bolt.
Tighten to 142 Nm.
Loosely install the subframe rear mount retaining bolt.
Install the subframe reinforcement plate retaining bolts.
Tighten to 35 Nm. Tighten to 142 Nm.
Install the tie rod end.
Tighten to 35 Nm.
Loosely install a new wheel hub nut.
Install the front road wheel and tire.
Tighten the wheel hub nut.
Tighten to 330 Nm.
Check the subframe alignment.
May 20, 2010 | 2002 Jaguar X-Type
Passenger side wiper slipping or not moving intermittenly
looks as though the nut that holds it may have come loose try tightening it , if it still slips remove it to see if the wiper arm is stripped. if it is ok u should see gear like teeth in the hole.
Jan 27, 2010 | 1997 Saturn SL
NEED INSTRUCTIONS ON REPLACING ALTERNATOR ON F150 FORD LARIET 1986.
See Figures 1 and 2
0900c1528004b8db.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Rear terminal alternator
0900c1528004b8dc.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Side terminal alternator
  1. Open the hood and disconnect the battery ground cable.
  2. Remove the adjusting arm bolt.
  3. Remove the alternator through-bolt. Remove the drive belt from the alternator pulley and lower the alternator.
Some engines are equipped with a ribbed, K-section belt and automatic tensioner. A special tool must be made to remove the tension from the tensioner arm. Loosen the idler pulley pivot and adjuster bolts before using the tool. See the accompanying illustration for tool details.
  1. Label all of the leads to the alternator so that you can install them correctly and disconnect the leads from the alternator.
  2. Remove the alternator from the vehicle.
  3. To install, reverse the above procedure. Torque the pivot bolt to 58 ft. lbs.; the adjusting bolt to 25 ft. lbs.; the wire terminal nuts to 60-90 inch lbs.
BELT TENSION ADJUSTMENT
The fan belt drives the alternator and water pump. If the belt is too loose, it will slip and the alternator will not be able to produce it rated current. Also, the water pump will not operate efficiently and the engine could overheat.
Check the tension of the belt by pushing your thumb down on the longest span of the belt, midway between the pulleys. Belt deflection should be approximately 1 / 2 inch; (13mm).To adjust the belt tension, proceed as follows:
  1. Loosen the alternator mounting bolt and the adjusting arm bolts.
  2. Apply pressure on the alternator front housing only, moving the alternator away from the engine to tighten the belt. Do not apply pressure to the rear of the cast aluminum housing of an alternator; damage to the housing could result.
  3. Tighten the alternator mounting bolt and the adjusting arm bolts when the correct tension is reached.
Apr 07, 2009 | 1986 Ford F150 SuperCab
Barcalounger Oracle II Recliner with Stargo Red Top Grain Leather Logo
172 people viewed this question
Top Barcalounger Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Barcalounger Furniture Expert? Answer questions, earn points and help others
