Question about Optics
Loss of GPS Signal and Yardages
It is often thought that a GPS device like the SkyCaddie should keep constant uninterrupted view and connection to the satellites, thus always giving accurate yardage information. This is true of cellular technology, indoors or out, etc, but not for a GPS device like the SkyCaddie. A clear, unobstructed view of the sky must always be maintained for optimum performance. Here are some other tips:
1. When going to play golf, the SkyCaddie should have a fully charged battery and should be allowed to search and acquire satellites for at least 10-15 minutes, prior to play. During this time, the device should be stationary. Many people power the device on then head straight to the course. From that point on, the yardage info you get may be off or may not show at all.
2. Is the golf course you are playing in need of an update? It's good to plug your SkyCaddie into your computer and allow it to sync with the SkyCaddie desktop software. You will receive updates to the device if you do this periodically and you can view your course list to see if any of your downloaded golf courses should need an update. An unupdated golf course on the device can cause yardage problems.
3. Placing the SkyCaddie in your pocket during the game, placing it in a golf cart cup holder, tall trees or heavy shrubbery, hilly terrain, very overcast cloudy days, etc., all can impede satellite acquisition and yardage accuracy.
4. Internal issues. Most SkyCaddie models may have an outward antennae view, but there is also an inward antennae connection that could be compromised. If this is true, the user will not know this, as this type of issue is internal and will need to be sent in to the company for repair, contact them to have this done. This can also be the source of why a device never seems to acquire satellites and/or give accurate yardage information.
on Aug 12, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
My buddy quit working
if your golf buddy has a battery in it, it might need a new battery
Mar 17, 2016 | GolfBuddy Golf Buddy VOICE GPS
It reads 10 to 20 yards shorter than actual yardage.
re-calibrate the unit or get a more accurate unit
20 yards for a cheap gps unit is about average
remember that you actual yardage is measured by the revolutions and circumference of the tyres so the difference could be coming from that area rather than from the gps unit
Aug 28, 2015 | GolfBuddy Golf Buddy VOICE GPS
Yardage is not showing
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Oct 28, 2009 | Bushnell Yardage Pro 1000 Rangefinder
I have no voice on my navigation
check to see if you have fm transmit on turn it off.
also for voice guidance you need to pick a voice with tts(text to speech picked) emily(tts)
Aug 14, 2009 | Garmin nuvi 750 GPS Receiver
Will not pick up the flag over 150 yards.
You need an alignment. The transmitter and receiver are not pointing at the same spot. The farther the distance the bigger the gap between the two. Dropping the rangefinder and vibration are killers to Pinseekers. Bushnell will fix ya.....
Mar 12, 2009 | Bushnell Pinseeker 1500 Rangefinder
My Pinseeker will turn on but will not give any yardage.
Sounds like the unit needs an alignment. If the crosshairs appear in the display and stay needs a CPU board and reprogramming.
Jan 13, 2009 | Bushnell Medalist Rangefinder
Bushnell yardage pro 600
I had a similar problem the first couple of years I owned my unit. I took the battery out between uses and that avoided the problem. I also made sure that the case was tightly closed so no light gets into it when not in use. The problem is now gone.
Jun 26, 2008 | Bushnell Yardage Pro 600 Rangefinder
Error code er6
Take the nice cover and neck strap off rangefinder to use on another item. Next use the rangefinder for hammer. boat anchor, etc. Seriously though the problem occurs often in the Bushnell rangefinders and it cost more to fix than to replace with a better brand. A $179.00 original cost rangefinder cost $10.00 to ship back to Bushnell and another $235.00 for repair of a non specified problem for a grand total of $245.00. I consider this a rip off from Bushnell.
Dec 09, 2007 | Bushnell Yardage Pro 600 Rangefinder
Optics Logo
64 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
