Question about Tablets & eReaders
My tablet wont or cant find the network to run on to make phone calls
  • kakima Dec 15, 2016
    Hi Bryce Taylor, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model tablet? What network?
Will not boot-up or start
Hi there, If your tablet will power on, but won't boot up, then take a look through this:How to Factory Reset Your Android Phone or Tablet When It Wont Boot
If it won't power on at all, try out these instead:
What to Do When Your Android Phone or Tablet Wont Turn On
My Android Tablet Wont turn on Anymore And cant take the back off
If those do not help, then contact the manufacturer.
I post on behalf of HP.
Jul 29, 2015 | Tablets & eReaders
Will not boot-up
If your tablet will not power up at all, then take a look at these two pages, with have some methods you can try.
If on the other hand it does power on, but does not boot up, then try this one instead:
If neither of those help, then I would recommend contacting the manufacturer.
I cant receive calls cant recharge
Switch off the phone take out the battery and then reinsert the battery again and try to make the phone on now.
Aug 17, 2014 | Samsung Galaxy Tab Tablet PC
Samsung galaxy note 10.1 edition make emergency calls
Your sim card or network is not recognised or detected. Make sure that you can see your network displayed on your tablet. If no sim card or network is detected by your phone or tablet, you can only make emergency calls
Apr 24, 2014 | Samsung Galaxy Note 10.1 Tablet - 2014...
I downloaded google phone ap. When making a call, i can hear them, they cant hear me
Was the ap specifically designed for the ipad? Try a different phone ap, worst case. Write a message to the developers about your problem, they are happy to fix any problems you run into. It helps the sales of there program, in one way or another.
Mar 23, 2014 | Apple iPad 32 GB WiFi Tablet PC
Cant answer viber calls
I dont use Viber myself, I can only suggest few things:
*check online to ensure your tablet is supported by Viber ( compatible to run that Apps) I know some phone wont work with the apps.
* check your viber to see your setting has "anyone" or "contacts only" this latter one means you can not receive call from people that is not on your phone book listing.
* try to see your volume is on inside the device setting (the audio).
Mar 12, 2014 | Samsung Galaxy Tab Tablet PC
I cant answer viber calls on my samsung tablet why?
Are you using Sprint? They stink! I often do not hear the ring tones and only the message tones after they have called.
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
Internet not connecting
  • Under settings on the tablet enable the wireless radio.
  • Once enabled you should get a list of available networks, select yours.
  • Enter any password you have.
  • If you get an authentication failed message and you know your password is correct, try disabling security on your network and try again. Some tablets have a problem with security especially those running ICS.
Dec 08, 2012 | Coby Kyros MID80244G Tablet
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
