How to fix EA error in Sanyo ASW-F101AT automatic Washing Machine ?
beltronic205
  • 1460 Answers
SOURCE: i have a sanyo ASW 40AP WASHING MACHINE now
If you are referring to the Spindle on the timer being loose ,this would suggest you may need a new timer quite an expensive repairif on the other hand its thewhole thing that is loose or the timer knob, both would be repaired quite cheaply...I wish you good luck
Posted on Oct 07, 2009
  • 5 Answers
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Posted on Oct 11, 2009
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
kapishtech
  • 2272 Answers
SOURCE: my sanyo washing machine does
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
  • 1082 Answers
SOURCE: Would you have a user
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
SANYO Owner ManualsTo find an Owner Manual for a SANYO product, enter the model # of the product below.
Please Note: We are in the process of upgrading the Owner Manual search to also include discontinued product documents. Please check back in a week or two if you need an Owner Manual for an older SANYO Product.
Model # ASW-F6OAT
Search Results
Sorry, could not find any documents that match your search criteria
Posted on Feb 21, 2011
  • 6277 Answers
SOURCE: my washing machine is SANYO
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 22, 2011
My machine is a SANYO ASW F101AT when I start the machine the water over fills and shows an ER. there must be level switch some where, How do I fix it
there is a water level switch and it is controlled by a small tube from the tub to the switch
as the water rises in the tub , the pressure in the tube over comes a spring tension in the switch that you set by wash load level
when that setting is overcome the switch powers the solenoid for the water inlet and shuts it off at the same time starting the wash cycle
so you have 2 possible problems
i--- level switch
or
most likely a problem water control solenoid or diaphragm in the solenoid
the fix for the solenoid is a new one
check the tube to the switch or check the switch
do that bu setting low water level and listening for a solenoid operation for the water
Oct 27, 2016 | Washing Machines
My washing machine ASW-F101AT loss its balance, when I opened the back cover, I saw the 1 of 4 balancer which is attached in every corner had been fall out, when I tried to put it back it doesnt hold the...
the rods have to be placed in properly and have a plastic coupling that it sits in they don't pop out very easily, so u may want to check to make sure u properly attached it, check the top and bottom where they connect and see if there is any corrosion or breakage at the link
Jul 26, 2014 | Washing Machines
Sanyo, washing machine, asw-ep70a
It probably needs a belt. It may have been slipping so much with the bigger loads that now it is shiny
Nov 29, 2013 | Washing Machines
How to open child lock on sanyo asw-a85ht washing machine
Apr 07, 2012 | Cars & Trucks
Would you have a user manaual for a Sanyo ASW-F6OAT washing machine? gusov@mcdermott.com
Model # ASW-F6OAT
Search Results
Feb 21, 2011 | Washing Machines
SANYO WASHING MACHINE ASW F 950 T DISPLAY E A FAULT CODE
I NEED TO FILTER ASW-F950 T,I AM FROM IRAN.MY EMAIL IS BEHAVARD@GMAIL.COM
Dec 14, 2010 | Washing Machines
My washing machine is SANYO ASW-90WRTP. showes E4 on the screen. I guess it means Error 4, but I don't know how to solve the problem. Thanks.
Oct 11, 2009 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
