Rinnai 2520 is beeping but no error code showing
2 Suggested Answers
  • 9 Answers
SOURCE: give me the solution for my canon image runner 2520 photocopier which shows error code e000002?
Well try this method unplug for 30 second and plug it back push start and off button at the same time and hold it for 10 second and let it go then try to text copy and see if it work
Good luck
Posted on Jan 21, 2015
My Rinnai tankless water heater keeps tripping the breaker then when turned back on, it begins to beep and displays a code 12. What is causing this? It is new and this is the first time any code came.
Go to Rinnai and get a manual with the error codes... for example a shorted element will trip breaker... wiring problems can cause breaker to trip... anything that causes heat on wire to exceed amp rating of breaker will cause it to trip...
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
Sep 12, 2017 | Rinnai Water Heaters
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
I have a Rinnai 516TR showing error code 62
Error Code 62, indicates a faulty fan motor. Which, according to your Owner's Manual, requires a service call by an authorized Rinnai service technician. it may not mean replacing the fan motor. It could also mean a faulty fan sensor.
Hope this helped you. Cheers.
Jul 08, 2011 | Rinnai Heating & Cooling
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rannai 2520
This is a water heater not a heater, sorry. Remove the ignition probe just below a small window and adjusst the gap after polishing the probes. Make sure all wires are connected good. Test fire unit.
Dec 19, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai tankless gas water heater and this things beeping and flashing 12 everytime we turn on the hot water the water will get hot but you have to wait for it to stop beeping
Error 12 is failed ignition - this can be caused by many things, but normally a low gas pressure, or no gas pressure upon ignition.
Try turning the hot tap on very slowly till till the control shows burner is lit. Then turn it on faster. If it stays going with no error, you might have a faulty regulator, not opening fast enough to meet demand. Especially common with lpg models,a lot rarer on natural gas.
Oct 27, 2009 | Rinnai Water Heaters
This things beeping and flashing 12 everytime we
check the error codes on it by pressing the on off button for 2 seconds then while holding the on/off button press the up button this should display the last 9 error codes let me know what they are
Jul 28, 2009 | Rinnai Water Heaters
No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Mar 22, 2009 | Rinnai Digital Remote Water Heater Control...
k24674
jasbo
jasbo
