Question about Cell Phones
I need a phone number so I can get info regarding a damaged and broken glass item
How do I change broken glass in 7024W?
do you mean a place that will fix it for you or are you planning on DIY repair. If you want to take it somewhere you could contact the manufacturer of the phone.
http://www.alcatelonetouch.com/global-en/support/faq/service.html
if you are planning on DIY it is real easy to damage the digitizer under the glass when trying to replace the glass. You can buy replacement glass but you need to heat up the glass to the point that the glue melts and the digitizer underneath does not burn. you have to lift the glass gently and bit by bit without putting pressure on the digitizer. suggest looking at Utube videos on how to replace glass on various mobile phones. If the digitizer is already damaged you have to replace the digitizer which is costly and involves pulling a mobile phone to pieces and re assembling it.
Jan 20, 2015 | Cell Phones
Can a broken **** phone be repaired?
It depends on how it was broken. If only the case is damaged, most shopping centerkiosks have replacement shells - if any of the internal circuit boards are damaged, you will want to send the unit in for replacement. If the warranty is up, you're looking at a new phone. The cost of electronics repair is often more than the device itself.
Car Accessories
May 23, 2012 | Sanyo Katana LX Cell Phone
Need new door glass
Hello there and welcome to fixya
You can either get this glass from the manufacture or there is a site called repair clinic.com that does have this glass . I was just there and they have it
Here is the info
Inner Door Glass
Item # 830392
img-descriptiontab-on.png Inner microwave door glass
Manufacturer Number 8172125
More
Promo Price
$82.70 $74.45 Quantity:
Out of Stock
(usually ships within 7 - 14 days)
1-800-269-2609 for calls within the 50 states.
1-734-495-3079 for calls from US Territories and APO/FPO bases.
Orders received by fax are processed within one business day. 1-734-495-3842
Sep 16, 2011 | Whirlpool MH6140XK Microwave Oven
My glasses are turning white? thank you
This eventually happens to all glasses in dishwashers, especially if they're lead crystal. Only Pyrex and similar types of glass are somewhat resistant to the problem.
The whiteness is usually irreversible: it's caused by a craze of microscopic cracks in the glass surface, effectively etching the glass. There is only one occasional exception and that's where the fogging is caused by microscopic limescale deposits in the cracks when they're still not present in sufficient numbers to cause white fogging on their own. Adding a cup of white vinegar to the final rinse (if your dishwasher allows the door to be opened mid-cycle) usually clears such glasses, but is not a sure thing as those glasses are already damaged to some degree.
There are dishwashing powders/liquids/tablets which claim to be glass-friendly, but all they do is to delay the onset of glass etching. Even commercial glass-washing machines don't completely avoid the problem, but in commercial use glassware rarely lasts long enough to become cloudy.
You only have two sure ways to prevent this being a problem in future:-
1. Never put valued or lead crystal glasses in the dishwasher and to regard all others as replaceable items.
2. Handwash all glasses.
I hope that my speedy answer has met your requirements; please take a moment to rate my response.
Mar 08, 2011 | Siemens Dishwashers
Item number: 120623310774 Buyer User ID: dwol2110 Seller User ID: mythings0909 This was described as a 5 quart Pyrex glass lid. It is a 2 quart glass lid. With shipping, I paid $29.20 for nothing, since...
I have viewed the item and it is described as "5Qt" It is possible that it was simply an error by the seller when listing the item or they may have sent the wrong item by mistake.
You should contact the seller first to see if it can be resolved between you. If not, you can use eBay's "Resolution Center" which can found in the top right corner of the eBay page under the "Help" menu -or you can click on this link to go directly there:
http://resolutioncenter.ebay.com/
Check the option "I received an item that does not match the seller's description" then click the blue "CONTINUE" button. You will then need to sign in to your eBay account to continue the process. Just follow the on-screen instructions and select the options that are relevant to your situation.
Always contact the seller first though. You should only use the resolution center when you have already tried to resolve the issue directly with the seller and failed.
Hope this helps.
Regards,
BElectric
Dec 10, 2010 | eBay Auctions
I tried to purchase an item had trouble with my pay-pal password... Decided to just use credit card email said success but I don't think so... No charge in 8 days on my bill... how can I tell if this sale...
Okay, with regard to your concern, looks like you paid for the item and select to pay using Credit Card, but since the seller's Merchant credit card account is not integrated with eBay, you wasn't able to enter your credit card details and the card wasn't charged. In this case, you'll need to contact the seller first. You can actually request for their phone number so you can get an immediate response. You can ask the seller to process the credit card payment. You'll give yoour card details over the phone, make sure that the seller is a trusted eBayer, you can tell that by looking and reviewing his Feedback profile. Hope this helps!
Here are the steps on how to request for the seller's phone number:
1. Please click on the Advanced Search link on the top right hand side of the page.
2. Then on the left hand side of this page, under members, please click on 'Find Contact Information'.
3. In the Contact Info section on that page, type in your trading partners User ID and the item number.
Jul 17, 2010 | eBay Auctions
Broken Glass on Cooktop
Ouch. The glass top does have to be replaced but I just ran the partial model number on your range and if you're at the comp. I hope you are sitting down. Replacing it not bad. Purchasing tho is rediculous. Retail suggested price just for the top is 600.00. Rediculous pricing but GE is like that sometimes. Sorry but repairing the glass is not possible and getting it from a glass shop isn't either. Sorry for the not so good news. Rick
Mar 01, 2010 | GE JSP57 Electric Kitchen Range
I need a glass tray for my NN-T664SFX
go to this website
http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp
you can either search by model: enter NN-T664SF and click the part number box, then find the tray listed under accessories. OR
you can search by part number from that same link. Enter F06014T01AP and click retrieve part info. Once you add this to your shopping basket you will see two items listed, as the original model has been replaced by another model. Click verify availability... and the shopping basket will adjust and only show one item in the cart, which will reflect the replacement model item. Finalize your purchase from there by entering your personal info. Good luck!
Oct 06, 2009 | Panasonic Microwave Ovens
I need a screen for my 19inch dynex lcd tv where do i order that
HELLO
To get a new LCD screen installed will cost the same - or more - than a new TV. They are not as tough as your glass screen CRT TV's one good whack and it's totalled. If it's broken or simply worn out there's not much you can do.
My advice is: buy a new TV! Sorry but that's the game regarding LCD TV's! (:-(
Oct 04, 2009 | Dynex DX-LCD32-09 LCD TV
My razr 3c has a broken front glass the lcd is still working . I just need to get the glass replaced?
Hello
You can get the front lcd glass at motorola service center, or you can visit in this site for more info about motorola accessories motorola glass i hope you enjoy this site...
Angel
Thanks...
Jul 31, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
