Question about Samsung Dryers
I have a Samsung dryer model DV328AER/XAA that is blowing the thermal fuse. The vent is clean and the element is about a year old. What should I look for next. (blown three thermal fuses)
  • Samsung Master
  • 10,045 Answers
Sounds like a shorted heat element.
Posted on Dec 18, 2016
Testimonial: "Nope. It was the thermostat"
My Samsung DV488AEW/XAA Dryer keeps blowing the thermal fuse. It has good airflow; there's no lint buildup. I've replaced the fuse 4 times now and also the thermal cutoff and the heating element. Help
Check the airflow if it is restricted at the output, you need to have the vents cleaned. The airflow is backing up and causing overheating inside the unit.
Oct 15, 2015 | Samsung Dryers
Dryer wont heat, replaced thermal cut off and it worked for maybe5 minutes and then it quit heating and now there is no continuity on the new thermal cutoff...I was wondering if there could be a short
The most likely cause of the thermal fuse blowing out again is either a grounded element or a clogged vent. I am assuming you have an electric dryer. If so, unplug the dryer and find the terminals to the element. Remove one of the wires to the terminals and use an ohmmeter/continuity meter to check between the chassis ground and one of the terminals on the element. You should not read any continuity. If you read a short, then the element is grounding out to the chassis. Replace the element.
If the element is okay, then the vent is probably clogged. After replacing your blown thermal fuse with a good thermal fuse, unhook the vent hose off the back of your dryer and run your dryer through a full cycle. If it doesn't blow the fuse, it's your vent and you'll need to clean it out and make sure no birds built a nest in there. If your thermal fuse still blows, replace all of your thermostats.
Oct 25, 2014 | Dryers
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Oct 14, 2012 | Whirlpool Dryers
Kenmore 80 series dryer approx 7 years old not heating anymore. Cleaned the vent pipe using semi-rigid vent tube only three feet to outdoors. Vent on exterior blowing cool air forcefully. It is an...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a link to a video that will help you.
Nov 26, 2010 | Dryers
I have samsung front loader model #DV328AER/XAA quit heating could it be the heating element or a switch
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Sep 20, 2010 | Samsung Dryers
I have a May Tag dryer which blows the Thermal Fuse.
I am not 100% sure, but I think that the model that maytag had with that dryer. When I was working for my local dealer I had to change several of those, and it about 2 weeks time they blew.
Aug 09, 2009 | Maytag MDE308DAYW Electric Dryer
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
No heat
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Dryers Logo
103 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
