Question about Tablets & eReaders
Tablet is overheating, what can I do? - Tablets & eReaders
Why does my coby tablet get so hot then shuts down and restarts?
Reduce the applications used at one time to prevent overheating. Overheating will cause automatic shutdown in most electronics to prevent damage.
Jul 22, 2015 | Coby Tablets & eReaders
When traveling to countries with 220 voltage, is there any danger of overheating my ellipsis 8 android tablet, or should I use a voltage converter?
You can't use your current 110 V converter. Should go to a local accesory store selling converters for your tablet and buy a 220V converter with output SPECIFIED FOR YOUR TABLET - mean, voltage and amperage.
Even using a 220 V converter, you can fry your tablet by not using the PROPER converter.
Jul 01, 2015 | Tablets & eReaders
Why does my Samsung 8.0 tablet keep saying device is overheating?
That does not sound right. I have had several Samsung tablets and never saw that. If the tablet it new it sounds like it might be defective.
Feb 12, 2015 | Samsung Tablets & eReaders
How can i prevent my nextbook premium8hd from overheating
Tablets are designed to not heat up much at all, let alone overheat. If it is overheating, there is a hardware problem that is causing that. If it is still under warranty, get it replaced.
Aug 25, 2014 | Tablets & eReaders
Tablet screens has lines thru it
Sounds like it is either overheating, or the video card is going bad. If it is overheating, make sure the small vents are clear of obstruction, such as lint or dust as that might be the problem.
Apr 12, 2014 | Tablets & eReaders
Go clever terra 70L will not power on
I have same problem. I put mine tablet in the freezer about 2 hours. Then i put tablet in charger and then i press power on button.
It seems be somekind of harware issue or overheating.
Sorry my bad english
Dec 27, 2013 | Tablets & eReaders
Why is my Toshiba tablet freezing
It could be a number of things. Too many programs running. Or prolonged use while on charge could cause overheating.
Jan 03, 2013 | Tablets & eReaders
Coby touchscreen internet tablet for android will not come on. i had it plug in all night screen will not show anything
I would guess that it overheated. You aren't supposed to leave them plugged in for extended periods of time.
Mar 21, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
