Question about ASUS Eee PC 1000H Laptop
Dell latitude d600 jumping curser
Cant type in online boxes without jumping
then i have to click in the type box again
Software for a dell latitude d620
It's the wireless switch used to toggle the wireless on and off.
Read the Manual
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals and check them out for a visual of what is on the computer's left side.
The link for the manual is below.
http://support.dell.com/support/edocs/systems/latd620/en/UG/about.htm#wp1161929
#6 on the picture is the Wireless Switch
May 17, 2012 | Dell Latitude D600 Notebook
Enternet controller
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.
Mar 28, 2012 | Dell Latitude D600 Notebook
How do I disable the touch pad on my Latitude E5400? The curser jumps all over when I type. On my other laptops, there is a button clearly marked to disable the touch pad and this has solved the problem....
  1. Click Start.
    Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  2. Click the Dell Touchpad tab.
  3. If you are not getting the Dell Touchpad tab, update your driver, you will get the Tab.
  4. Click on the picture of the touchpad.
    Click Device Select.
    Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
    Click Apply, then click OK.
  5. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Aug 31, 2010 | Dell Latitude E5400 Laptop
How to restore to factory settings latitude D600
hi,
the d600 has a 8 pins chip,like the c600 where the pasword/faxtory
setting is stored..
it's located under the tape where the pcicma socket is..close to edge of the board
it sais:UPW1
I think you can use the paperclip methode like the c600
wich means short two pins ( 3& 6) while you power the lap
May 20, 2010 | Dell Latitude D600 Notebook
I cant connect my dell latitude d600 to the internet via ethernet it says its connected but browser wont work??
Try to disable your internet connection. Right click My Network Places in your desktop and chose Properties. Right click the network connection and disable. And make it enable again. Now try to browse website,now it work.
Mar 30, 2010 | Dell Latitude D600 Notebook
Restore dell d600 to factory settings
Resetting a Dell Latitude to the factory settings allows the user to restore the Dell Latitude to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1: Before reset any Dell Latitude laptop, backup your all important data and programs, otherwise you may lose it. It is recommended to use an external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Latitude laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Latitude reset process...
This process will erase all your previous changes that have been made to the Dell Latitude laptop and reset the configuration settings to factory setting.
Feel free to get technical assistance
for all models of Dell laptops(Vostro, Latitude,Inspiron...etc..) at http://www.vtechsquad.com/dell-support/
Mar 25, 2010 | Dell Latitude D600 Notebook
Dell Latitude D600 PC Notebook
your s-vidio out on the laptop only transfers vidio, you need to use a headphone to rca jack cable pluged into your headphone port on laptop and plug rca into back of tv or vcr or s-vid converter box
May 31, 2009 | Dell Latitude D600 Notebook
Curser skips around a lot
Clean the touch pad,and if this dosn't work update synaptics touch pad driver.
May 23, 2009 | Dell Latitude D600 Notebook
Dell LAtitude D600 mic wont work
right click on volume in right hand toolbar and open volume control then click options and then properties tick all boxes scroll along to mic and turn slider up should fix.
May 08, 2009 | Dell Latitude D600 Notebook
Cursor skipping and jumping back into previously typed text
Have a D600 myself and found anothe post that worked for me!
First, my problem was replying to emails the cursor would jump when typing usually back up into the middle of the text somewhere.
If this is similar, read on.
First, go to Dell's website, downlaod the latest driver for the Alps Touchpad: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R113813&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=2514&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=149404
Download the driver but do not install yet. Note, this is for a Dell Latitude D600, Windows XP. Vista may have a different driver.
Open Control Panel/Mouse/TouchPad Tab/Touch Sensitivity Button. Open Touch Sensitivity, adjust below the halfway point on the slider. Try different settings, you may also want to check the "Tap off when typing" box.
If you do not show these properties as above, you probably don't have the latest driver installed. In that case, install the driver you downloaded above then come back and refer to the instructions.
I spend 90% of my day on this D600 and really love it, not a speed demon, but light enought to carry with one hand and is a great email/browser machine as you probably already know!
Before installing tis driver
Apr 04, 2009 | Dell Latitude D600 Notebook
ASUS Eee PC 1000H Laptop Logo
95 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
