Question about Brother Office Equipment & Supplies
Unable ti init. AF on brother DCP - J 125 - Brother Office Equipment & Supplies
Mix-it-up
  • 832 Answers
SOURCE: init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Posted on Sep 13, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother DCP 115C displays unable
press menu then start b/k-copy (mono) then fortimes arrow up button quickly after another. machine will switch to mainteance mode. press start bk copy.
What two digit error code does the machine display?
Post here again.
Posted on Mar 09, 2008
  • 5 Answers
SOURCE: scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
Posted on May 15, 2009
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
SOURCE: Error: init unable 50
init unable 50 how to resolve this problem..?
Posted on Jun 28, 2011
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
Unable to init 4f
Problem with Brother DCP-J125
Unable to init 4f
Aug 06, 2013 | Brother DCP-J125
Dcp j125 unable to init 48
Unable to Init 48 printer Brother DCP-125 ???
Jul 28, 2012 | Brother DCP-J125 Inkjet Multifunction...
Init unable AF, DCP185c
brother dcp 195c init unable af problem solve solution
Apr 04, 2010 | Brother DCP 165C Compact Color Inkjet...
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
