WILL WORD PERFECT NO0 RUN IN WINDOWS 10 WITH OUT PROBLEMS WIL WORD PERFECT NO9 RUN ON A 64 BIT SYSTEM WHAT VERSION OF WORD PERFECT WILL RUN ON A 64 BIT SYSTRM ??
matchbox2022
  • 46 Answers
SOURCE: I can't to install Windows vista 64 bit within a 32 bit
WELL if you are trying to INSTALL windows 64bit, it's pretty simple.
You may or may not be required to format your hard drive for this, so be wary, BACKUP all your information that you want to keep onto dvds or another harddrive before doing this.
Ok with that warning out of the way, the simplest way to do this is to simply either take out your hard drive and format it using another computer, or doing it on your computer by selecting my computer, right clicking on your C: and pressing format, and selecting quick format, and letting her rip.
Now, ALL your data will be gone, because you are installing a new operating system. If you do not want to install just vista 64 (if you want to keep your old OS) then do not bother formating and just skip to this step.
You want to load the DVD into the drive and reboot the computer.
Now you should be able to press a button F-something (like F2, F8 or F12) to allow you to choose what to boot from (you may have to go into the BIOS and tell it to boot from the DVD drive first, before the harddrive, which won't hurt your computer at all). Just simply select your dvd drive and windows vista should boot properly. If you don't see a startup screen right away, just try typing setup or windows and pressing enter. Follow the on-screen instruction, and you will have a brand new operating system, which is running on 64bits.
BE SURE that your computer has a processor that is 64 bits before doing this, otherwise it will not work. Any software you use on vista 64 bit needs to be in 64 bit, just like how any software written for 32bit needs to be used on a 32 bit operating system. You can't usually install an Operating system...within an operating system, well, I've never done it personally.
Hope this helps, stay spicy and happy lappying! :)
Posted on Dec 16, 2008
T3KK
  • 171 Answers
SOURCE: i m using vista home premium 64 bit opreting
You can right click on the program and select properties - this will let you run the program as if under different OSs...
Alternatively, you can install VirtualBox, install a 32bit OS on that like XP and install Turbo C onto that so it works....
finally you can upgrade your Turbo C to Microsoft's free Visual C Express available here - I would suggest this as your best option as it is more modern, better environment and gives you several more years of use than you have with Turbo C
If this helped you, then please help me and vote - thank you
Posted on Oct 12, 2009
SOURCE: I am running windows 7
Hello:
You will find this is a problem many are having with Music Match as it is know not to run well or run at all in Win7.
Check this out on Brighthub.com http://www.brighthub.com/computing/windows-platform/articles/88178.aspx
I also used Tweaknow Registry Cleaner to help clear the registry of MusicMatch, and manually ran regedit and deleted any references to MusicMatch.
You will also have to change the Recorder Setting to the proper path for your files. If not, you should be able to burn files but not play them, or edit them.
Posted on Jan 03, 2011
SOURCE: i am trying to install
You don't actually need a driver to set it up. Just plug it into your network, then browse to its URL (likely 192.168.1.1, but could be 192.168.0.1, or 192.168.2.1). Then just follow the prompts to configure it. Hope that helps.
Posted on Feb 28, 2011
luciano_rpg
SOURCE: How do i get Muppet Treasure Island to run of
Try to use Windows XP Mode in Windows Virtual PC. I'm running Windows 7 64 bits and this solution works to me. =D
Posted on Jul 14, 2012
Install autodesk maya 2010 64bit
Okay the first thing even though your question is very general and we really don't know the specific probably having if you're installing an auto 64-bit you need these operating systems listed below make sure you have one of those operating systems it must be 64-bit you need to check if your operating system is 64-bit before you can stop go to the Run command on your operating system and type winver then enter an then enter and see if and seethe computer is if the computer64bit if it is not 64-bit you need a 64-bit computer first and foremost if you're having other problems you need to give us more details before we can help
If you're having a license key issue you may not actually own software or maybe counterfeit you need to contact Autodesk in that case good luck
The 64-bit version of Maya 2010 software is supported on any of the following operating systems:
  • Microsoft Windows Vista Business (SP1 or higher)
  • Microsoft Windows XP x64 Edition (SP2 or higher)
  • Red Hat® Enterprise Linux® 5.3 WS operating system
  • Fedora™ 8 operating system
The following web browsers are supported for Maya 2010:
  • Microsoft® Internet Explorer® 6.0 internet browser or higher
  • Netscape® 7 web browser or higher
  • Apple® Safari® web browser
  • Mozilla® Firefox® web browser
Hardware
At a minimum, the 32-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows: Intel® Pentium® 4 or higher, AMD Athlon™ 64, or AMD Opteron™ processor
  • Macintosh® computer: Intel-based Macintosh computers
  • 2 GB RAM
  • 2 GB free hard drive space
  • Qualified hardware-accelerated OpenGL® graphics card
  • Three-button mouse with mouse driver software
  • DVD-ROM drive
  • Maya Composite media cache requirements for playback:
  • 10 GB minimum, 200 GB recommended
  • HDD: IDE, SATA, SATA 2, SAS, SCSI
At a minimum, the 64-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows and Linux: Intel® EM64T processor, AMD Athlon 64, or AMD Opteron
  • 2 GB RAM
  • Qualified hardware-accelerated OpenGL graphics card
  • DVD-ROM drive
Mar 22, 2018 | Autodesk Computers & Internet
Currently running Windows 7 Pro. Have a virtual PC to run 32 bit XP programs. If I install Windows 10, will virtual computer still work?
No. Not now. But Microsoft is working on a 32 bit version of windows 10. After it is released in the future, you can install the 32 bit version of windows 10.
Nov 30, 2015 | Computers & Internet
How do I fix this? Unsupported 16-Bit Application
You are trying to run a 32bit version program on a 64bit system, this is not allowed. Try obtaining the 64bit version of the program and load that or alternatively try CutePDF, it works well on any system.
Aug 06, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Rainbow six vegas 2 running slow? This game is running really sloooooooooooooooow on my desktop computer. These are my sistem specifications with updated videocard. I already tried changing to best...
i had the same problem. First, try downloading any patches that maybe be new, they can help.
then once in the game menu, go to the options and decrease the visual effects and graphics. they made this 2nd game to run in defalt mode with HIGH graphic computers, but if you just lower things to 800x600 and then set things to low, the gaame should run better, wont be perfect, but you will be able to play it with out getting mad at it..lol
Sep 23, 2010 | Rainbow Six Vegas - PC Games
How do i tell the diff between 64 bit and 32 bit windows xp
Method 1: View System Properties in Control Panel loadTOCNode(4, 'moreinformation');
  1. Click Start, and then click Run.
  2. Type sysdm.cpl, and then click OK.
  3. Click the General tab. The operating system is displayed as follows:
    • For a 64-bit version operating system: Windows XP Professional x64 Edition Version < Year> appears under System.
    • For a 32-bit version operating system: Windows XP Professional Version <Year> appears under System.
    Note <Year> is a placeholder for a year.
Method 2: View System Information window loadTOCNode(4, 'moreinformation');
  2. Type winmsd.exe, and then click OK.
  3. When System Summary is selected in the navigation pane, locate Processor under Item in the details pane. Note the value.
    • If the value that corresponds to Processor starts with x86, the computer is running a 32-bit version of Windows.
    • If the value that corresponds to Processor starts with ia64 or AMD64, the computer is running a 64-bit version of Windows.
Feb 11, 2010 | Computers & Internet
Trouble Installing COSMI Perfect Accountant Platinum
I'm Working as a Technician! You can explain your problems to me by dialing my toll-free number +1 (844) 355-5111.
Regards
Jun 30, 2017 | Cosmi Perfect Accountant Platinum...
27 people viewed this question
k24674
jasbo
jasbo
