Question about GPS
How do I get sound on the sat nav setting I have checked the volume control and it is set to highest
SOURCE: vdo dayton ms5000 sat nav
i need a booklet on how to operate the sat nav , any answers ?
Posted on Dec 29, 2008
SOURCE: Blaupunkt sat nav problem
when insert the adress it doesnt recognized and give wrong direction
Posted on Apr 08, 2009
SOURCE: very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Posted on Jan 24, 2010
SOURCE: SANSA Clip 4GB: Suddenly the output volume is very
My 8Gb Clip did the same after a firmware update. Apparently it's due to new EU regs about MP3 player volume limiting. To fix select 'reset all' (note any settings you want to re-set later), after reset, select your language and then set region to 'Rest of World'. Sorted!
Posted on Jan 22, 2011
spectaculusc
  • 321 Answers
SOURCE: Sat nav won't reset. have tried the re-set button.
If the reset button of your device is not resetting the device and it is still on the frozen screen. Just turn to the back of the device, unlock the battery from the device and remove it. Then you allow the device rest for about 5 minutes then you fix it back in. Plug the device for about 2 hours and power it on. It should work fine after this. Be sure not to turn on too many applications on the device at the same time time, because that could result in the device being frozen again.
You can as well update the software of the device by charging it for about 2 hours, then you connect it to the computer that has its software. That will show if there are recent updates for the device, then you update the software with the latest version. that should take a little while to update. Then install your maps on it, safely disconnect the device from the computer and turn it on. That can also help you solve the problem.
Hope this was helpful. Thank you for using fixya.
Posted on Jan 26, 2011
My binatone a435 sat nav is not talking to me
Did you hurt it's feelings by ignoring her to often so she is in the huff with you
have you checked the volume and voice settings
Feb 15, 2017 | Cell Phones
Have paired the sat nav with phone and they are seeing one another, but when I click the answer call on sat nav no sound is coming from sat nav have turned volume fully up can u help regardss
Search Results
    Troubleshooting voice navigation issues, including vehicle ...
    productforums.google.com/d/topic/maps/NR6xxNE5vQw
    Google
    Aug 21, 2014 - 100+ posts - ‎100+ authors
    Basically to work like a satnav does. .... Have been using Google maps and voice navigation with no prles since May. ..... The audio does come out from the phonespeaker even when my Bluetooth is paired to the phone.
Oct 24, 2015 | GPS
I have a Mondeo titanium 2010 with a Blaupunkt sat Nav SD card version. the screen suddenly went blank, not only leaving me with no sat nav but also no control over heater, air con, no radio volume. the...
Search finds little on your problem which is odd. I think you need a visit to the Dealership. when was it last serviced? Book it in for service and and ask them to look at that at the same time. You will get a better price and value for money.
Mondeo titanium 2010 Blaupunkt sat Nav SD card version the screen suddenly...
Nov 19, 2017 | Blaupunkt GPS
Sat nav not speaking
Mercedes commans sat nav version 4.1 for E220, is saying off road, and when at home is showing on map that I am somewhere in the National Park Peak District. I have been told to remove fuse for sat nav should be no 28 but in boot of car near sat nav cassette fuses in box only go upto 20. Am I looking in the right place?
Sep 12, 2012 | 2009 Ford Focus
My volume is not working correctly. I have it turned up to 100 - the highest and I can barely hear it.
Monitor volume is affected by TWO volume controls (or even three...)
1: Volume on the monitor can be set to 80%
2: Main Volume on the COMPUTER can be set to your liking.
3: Wave volume on the computer mixer settings should be set for 80% (See Sound on your control panel or right click your volume control near the clock)
If all these are right and the volume is still low, check that the audio is not set for surround 5 or 7 channel and the monitor audio connector is plugged into the REAR green connection on the computer.
Still problems, the audio driver in the monitor is shot.
Dec 05, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Low volume
hi, have you tried new drivers? how are the connections,cables?and check all the volume controls-look in control panel-sound devices.ect. hope this helps.i see you posted this a while ago.
Oct 31, 2008 | Creative Labs Sound Blaster Live 5.1...
Sat nav
GO TO PREFERENCES ,LOCALIZE , LANGUAGE, UK OR US ENGLISH . EXIT BACK TO LANGUAGE , TAP VOICE , MALE / FEMALE TAP TICK . ALSO INCREASE VOLUME ON SIDE OF NAVMAN + OR -
May 02, 2008 | Navman F20 GPS Receiver
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
independently controlled for all programmed devices.
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected
Mar 15, 2008 | Polaroid FLM-2632 Television
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
