Where can I get a thermocouple for model C-3329 new buck gaslog
3329 in cribbage score
hi tyler.
sorry i am not a player.but go to this link might help you out.
3329 in cribbage score Google Search
Nov 05, 2017 | Computers & Internet
I'm new to woodworking and using a router. after my father in law passed away we found his black and decker router model 3329. i don't have the owners manual, but am trying to find. Need to know...
you will need a think wrench to loosen the nut. find a local woodworker store if you dont have one or order off line. big box stores dont sell the tools seperate..
Jul 08, 2011 | Garden
Heater shuts down after about one minute pilot light is large plenty of ventilation
I would try changing the thermocouple when they get old they sometimes corrode or oxidize whatever the word is and the coating causes it not to work right. Usually when we have had to replace ours it is under 20 bucks. I hope this helps you
Mar 07, 2011 | Heating & Cooling
I changed the thermocoupler but problem remains the same: pilot goes out after about 10-15 minutes. I have Williams model 250912. Please help! How do I test if new thermocoupler is also bad, beside...
Remove the thermocouple and take a pencil eraser to the hole. Clean the corrosion out the hole. Reconnect the thermocouple tight. The tip of the flame must hit the tip of the new thermocouple.
If the flame is hitting the middle of the thermocouple that is called wash through (no good) The bimetal tip of the thermocouple is made of nickel and copper layered. When heated it produces millivolts. This holds the electromagnet in and that is your safety feature. Thank you Ralph Nader.
Jan 30, 2011 | Williams 2509612 Ceramic Mid-Size Heater
Will lite but goes out within a min
Make sure the thermocouples not fully engulfed in flame, it needs to be on;y at the tip end as they operate via temperature differential acrosss the thermocouples surface, if the whole thinfs one temp it drops out electrically(makes 30 millivolts) and the electromagnetically operated pilot safety valve closes, thus stopping the main burners operatin as its sensing no pilot exists. try a new thermocouple, about 15 bucks, and set it as described in pilot flame, if that wont do it, the gas valves bad.
Nov 01, 2010 | Blue Rhino ES200209 Open Flame Gas Patio...
Can't light pilot on rudd model urcf 07e24jkr
If your furnace indeed has a pilot, a thermocouple or gas valve is your culpret. Thermocouple is about ten bucks from The Home Cheapo so it is a good inexpensive start. That is the copper stick that the pilot flame hits. Turn off the gas and electric when changing it. If it still won't light then you will need a qualified HVAC tech to replace your gas valve.
Dec 12, 2009 | Heating & Cooling
I have a set of new gas (LP)fire logs just installed pilot will not stay lit manual says check flame to thermal couple but there is not a thermal couple visable. nor is it listed in parts manual. It is a...
The thermocoupleis about 3/16" in diameter and slides up through a hole right beside the pilot flame. Sometimes it doesn'tget pushed up far enough to come out the top into the flame. check the bottom of the pilot assemblynext to the silver pilot tubing, there the thermocouple is attached to a very small copper tube( 1/16") and this tube runs back to the gas valve. If it is there see if you can push iy up into the hole next to the silver tubing. unless the thermocouple can feel the flame the pilot will not stay lit, Hope this helps.
Oct 01, 2009 | Heating & Cooling
I have a 2 barrel carb off a 283ci 1967 chev carter carb
no spring poss small wire from needle to float! the way it works is float is up needle close because float bowl full--when fluid or gas goes down valve opens lets fluel full pump disconnect line at carb crank over with guage should have apprx 7psi of press not less then 5psi carefull gas flameable
Aug 30, 2009 | Chevrolet Chevy Cars & Trucks
I have a Peterson Real-Frye ceramic vent-free fireplace/ log set in my bedroom and my problem is that the log set constantly shut off and the piole goes out. What is my problem and how can this problem be...
there is a thermocouple which is a piece of metal that sits in the pilot flame if this is not in the flame the pilot will go out if this is bad the pilot usually will not light or stay lit let me know if this is useful or of any ?'s
Jan 06, 2009 | Heating & Cooling
Pilot Light
You need a new thermocouple they are about 5 bucks at a hvac supply store. Or you can get them at a hardware store. you can take the one out and go down and get the same length. In brief the thermocouple keeps the gas supply open to the pilot light.
Dec 01, 2008 | Procom Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
