Question about Video Game Consoles & Games
How to get a vhs tape ejected on a toshiba dvr650ku
I tried to eject it but it is stuck
    Top Expert:
  • Video Game C... Master
  • 8,248 Answers
You may have to open it up, whatever you do dont try and just pull the tape out you could end up doing more damage.
Posted on Dec 15, 2016
  • 3 more comments
  • Anonymous Dec 23, 2016
    I opened up the unit, but I still can't get it out. is there a trick to releasing the tape out of the tray?
  • NOEL
    NOEL Dec 23, 2016
    no there is no trick to it,if you can not free it up by just getting the tape from around the drive wheels or what ever its hung up on then you are going to have to cut the tape.
    when you press to get the tape out can you hear the gears trying to eject it out?
  • NOEL
    NOEL Dec 23, 2016
    goto this link and read on how you might be able to get it out...http://www.leaders-site.com/stucktape.ht...
    thanks for the tips. I got it freed up and the unit now works. thanks again and Merry Christmas!!!
  • NOEL
    NOEL Dec 23, 2016
    you are very welcome and merry christmas to you as well glad you got it working.
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Tip
How to eject a stuck vhs tape.
I will show you how to eject a stuck vhs tape. I did this on the sony slv-d300p first, unplug it. Next, take out all the screws on the back. Take off the cover. Locate the loading motor on the right. Turn the gears next to it. After about 5 minutes, the tape should eject. While its open, take a CLEAN piece of paper, hold it up to the drum, and rotate it with the paper against the back. after 5 minutes, take the paper off and stop spinning. the paper may be dirty. put the cover back on, and try to put in a vhs c adapter with NO vhs c in it. when you put it in, it should spit it back out.
on Jul 15, 2010 | Televison & Video
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
My Panasonic Omnivision VHS won't eject
take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
May 09, 2009 | Zenith ZHX-313 System
SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Jul 11, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
STUCK TAPE
check the tip in my profile
Oct 20, 2007 | Philips VRA999PH VHS VCR
Toshiba M-752 Video Casette Recorder
Take the top cover off, and see if there is an obvious reason for the no-eject, as in tape spooled out and wrapped around something. Next, is the tape drawn back into the tape housing? Under normal operation this is done before eject. A defect in the tape itself, or in the VCR mechanicals can cause a no "pull in" condition. Otherwise, you could carefully try to assist an eject- push eject, lift lightly on the tape. Sometimes the entire carriage mechanism can be removed with tape in place, but often, screws holding this in place are obscured by the tape, and, if carriage is gear driven, proper gear alignment must be reestablished. This can be a tricky problem, getting tape out without damaging anything, especially since late VCRs are made rather fragile to start with.
Aug 14, 2007 | Toshiba W522 VHS VCR
Video Game Consoles & Games Logo
67 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
