Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
When opening the kodak home center got an error.
Kodak esp-3. When opening the kodak home center got an error. error code: 1-2010 system closed down, also, It is taking a long time to scan, especially multiple pages.
  • 295 Answers
It is a scanning error............ scanning usually take 1-2 minutes to scana document. make sure dat u've proper ink in ur cartridges. contact kodak@ 1800 21 6699 for further issues.
Posted on Jul 28, 2009
Error code 2075 keeps coming up when I try to scan a document to desk top what do I do?
To resolve this error code:
  1. Close Home Center Software.
  2. Go to Start>Computer.
  3. Show hidden files and folders:
    • Select Tools>Folder Options.
      NOTE: If the Tools menu is not available on the menu bar, press the <Alt> key on the keyboard, and then a menu bar with the Tools menu will appear.
    • Select the View tab.
    • In the Advanced Settings, select Show hidden files or folders.
    • Select Apply.
    • Click OK.
  4. • right click on the Kodak icon on your desktop and select properties. •Then select find target.
  5. Right-click AiOHomeCenter.exe.config and select delete to remove the file.
  6. Hide hidden files and folders:
    • In the Advanced Settings, select Do not show hidden files or folders.
    • Select Apply.
    • Click OK.
  7. Run Home Center Software to run as an administrator:
    • Right-click the Home Center icon, then select properties.
    • Select the Run this program as an administrator check box in the compatibility mode.
    • Click OK.
  8. Open Home Center Software and print or scan a job.
Jun 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Keep getting error 2075 when i try to use the kodak aio Home Center
    • Select Apply.
    • Click OK.
  4. • right click on the Kodak icon on your desktop and select properties. •Then on the general tab select find target.
    • Select Apply.
    • Click OK.
    • Click OK.
May 10, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 all in one printer home center wont work
hello,
Run the clear utility. Go to www.kodak.com/go/clear
Step by step instructions are provided in that website.
after that uninstall the AIO Home center.
In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
Choose KODAK All-in-One Printer Software
Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA
OS).
When the Install Wizard appears, click Next.
Select Remove from the drop-down menu for the Kodak All in One Printer, then click Next.
Click Next.
Click Continue.
Thanks
Neerak21
Sep 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Scanner
i definately need clarification on this from your side..........are you getting any error when you try to scan using home center?.........mention the error code if yes.........try and use the scanner and camera wizard in XP click on start button and go to all programmes and under accessories there would be scanner and camera wizard and in vista you will find it under control panel.........this is a work around to be very frank with you......mention the error msg if there is any so that i can provide you with resolution......make sure the home center is showing connected or disconnected........
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
Error code: 1-2036
go to Kodak easyshare support:
http://www.kodak.com/global/en/service/products/ekn026079.jhtml?CID=go&idhbx=easyshareswsupport
In the box under Find Answers, type the complete error code (without spaces), then click Search. An error code should be like 12x413x1304x
Cheers
Jun 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
220 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
