I have a 3 pack of remote control light plugs that will not respond to the remote, why?
Indication Light On, Black Screen, Unresponsive
I happened the same problem and the solution must change the power pack
Jan 25, 2014 | LG M2362D 23 in. LCD TV
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Remote control does not respond even with new batteries in, a red light at top of device blinks but the set does not respond
easy way to check if remote control is emitting IR signal is to aim it directly at digital camera lens(cellphone cameras work great for this) while pressing any button on the remote you should see bright light flickering on camera display, if there is no light remote is bad otherwise receiving device in the set is not working
Sep 02, 2009 | Televison & Video
Wii remote is not responding and every time i press a button the lights flash, after the battery was fully charged. I put regular bateries and nothing, either.
you might have to re sync the remote to the consol again open the front cover with the wii on press the red sync button then press the red button inside the batt compartment on the remote you will have to have reg batts in the remote to do this then put the rechagable pack back in this might help ive had to do this a couple times
Jun 20, 2009 | Eforcity Charging Station for Nintendo...
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Magnavox tv won't respond to remote or panel controls
Could be a bad remote board in the TV...make sure the remote is working by checking it with your cell phone camera
Jan 18, 2018 | Televison & Video
My TV won't respond to the remote control
If the remote is working but the TV will not respond, it means that the little IR receiver in the TV has stopped working. This is most likely because the receiver has burned out, but it could also have come loose. This is a very easy thing to correct, but the set should be serviced by a qualified tech.
Sep 03, 2007 | Philips PR0930X 9 in. Portable Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
