Question about Boating
1989 evinrude won't shut off, tried new switch, no help
3 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: 1989 wrangler 2.5L won't turn off with new switch
Hi there:Bad installing or a problem with the connections. The most likely problem is a bad ignition switch. To find out for sure, remove the plastic covers over the steering column and remove the 2 screws holding the ignition switch in place. Make sure the mechanism coming from the key is turning the ignition switch. If the mechanism works fine, replace the ignition switch.
I would suggest removing the ignition switch and checking the mechanism in the column to make sure it is actually turning the ignition switch off.
You could have a wiring problem, you will have to follow all the wiring from the ignition switch down the column and into the harness, there is sure to be a short in the wiring harness, that is if as you said you replaced the ignition switch for a new one.
To test this, remove the plastics around the steering column and pull out the wiring plug to the ignition switch, if the ignition turns off you have another faulty ignition switch if it stays on wiring harness has shorted out.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Posted on Jun 19, 2012
qumozheklj
  • 23 Answers
SOURCE: i have no spark on 1989 7.5 evinrude outboard motor
1973 to 1990 johnson evinrude outboard 2hp to 40hp 2 4 stroke cycle workshop service repair pdf manual/
http://www.repair-guidebook.com/1973-to-1990-johnson-evinrude-outboard-2hp-to-40hp-2-4-stroke-cycle-workshop-service-repair-pdf-manual/
Posted on May 29, 2014
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Jun 19, 2012 | 1989 Jeep Wrangler
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Replace a 1998 Johnson 115 engine with a 1989 Evinrude XP 150
Change controls and gages with the engine if you can.
Apr 27, 2010 | Boating
I have a 1989 evinrude outboard 225,that shut downonme on my way in. after my tow ini waieted a moth and turned the key again. itwould not start. after 5 minutes of random tries, it started and ran for 30...
check for water or contaminants in the fuel tank and carbys. If a fuse was gone it wouldnt let it start again.So you must have spark, which only leaves the fuel system, unless it is internal engine damage or wear
Apr 25, 2010 | Boating
How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Apr 24, 2010 | Boating
Looking for electrical diagram-wiring- for 1989 Four Winns 251 Liberator with twin 350 chevys and OMC outdrives
I would try a johnson/ evinrude/ bombardier dealer for the diagram. OMC was bought out by them so they should be able to help. However in the marine industry it can be hard any literature on older products b/c they only produce a limited amount of their products.
Oct 26, 2009 | Boating
Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
May 10, 2009 | Boating
Boating Logo
115 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
