Question about Dryers
My hot tube is in sleep mode how do I get it out
Put new board in but not sure dip switch is right
4 Suggested Answers
  • 2072 Answers
SOURCE: sleep mode
Needs the firmware ( machine operating software) updated to the newest level.
Posted on Mar 19, 2009
  • 5 Answers
SOURCE: Dip Tube
You may want to check the heating elements first. Where I live there is a lot of lime in the water that can coat the elements.
Posted on May 01, 2009
  • 77 Answers
SOURCE: sleep mode
well to wake it up you usually have to press a key(any key) to wake it up, try this video on removing the ram and see if it helps:
Hope it does : )
Posted on Apr 15, 2012
Low water pressure
Hi Bob,
You can determine if the tank is the problem by connecting a garden hose to the drain that is provided on most water heaters. Before doing this, be sure to shut of the electrical supply to the heater - otherwise you can damage heating elements if an electric type or waste fuel by heating an empty tank if a gas / propane fired type.
If you get a slow flow out of this drain, it means that somewhere in the cold water supply side to / in the tank - there is a problem. Inside the tank, the cold water is delivered by a "dip tube" that distributes the cold water to the bottom in the tank. Dip tubes are used in both electric and gas / propane fueled heaters. Here's a cut away view of a typical tank:
If the tube is clogged, or there is build up, scale or debris in the supply (cold water) side of the heater, flow rates will suffer. Likewise, if there is a problem with the output of the tank, it will directly affect flow as well.
If you get a good flow rate from the drain, then the issue is going to be on the hot water output side of the heater. Again, the same build up, scale, debris issues on the hot water out put pipe will cause problems with flow. Typcial tanks do not have dip tubes for the hot water side of the tank - as taking hot water from the top of the tank is most desireable and is furthest away from the cold water that rushes in to make up the hot hot water going out.
There's nothing really in the tank itself that can cause issues with flow outside of the dip tube, and piping to and from the tank.
Jun 29, 2012 | Water Heaters
Hot water comes on but then runs cold after a minuate then goes hot again. The water appears to be hotter downstairs
If you have lukewarm water.. and at times it's hot.. then warm. or after running hot for a while and it cools.. chances are you have a cracked or failing dip tube.
The dip tube is just what it sounds like. a tube that delivers cold water to the bottom of the tank.. to mix with the hot water.. this keeps the hottest water at the top for faster delivery.
If this tube is cracked near the top.. or along it's length.. you may get some hot water.. then cold.. then warm..etc etc.
They are inexpensive to replace.. but as always exercise caution and follow proper procedure to relieve pressure, water supply and power/fuel before attempting a repair.
Generally this tube is inserted right where the cold water inlet pipe is on the heater.
A good plumber or water heater replacement or repair company could inspect fix and replace for a lot less than a new water heater.
Best of luck
Apr 10, 2011 | Heating & Cooling
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Water not hot enough, have to open more than one hot water faucet to get hot water
The Dip Tube "The dip what?" you might say. In every water heater, there is a plastic tube parked in the cold port that brings cold water to the bottom of the tank to be heated -- and preventing it from mixing with already-heated water in the top of the tank.
If that falls into the tank or splits or breaks, then cold mixes with hot and suddenly your water heater doesn't work nearly as well as before.
There's a ton of Americans out there who know all about this because of a debacle a few years ago. The company that makes most of the dip tubes in this country changed its formula for the plastic. The new plastic was prone to disintegrate in certain conditions. The operative time period was August 1993 to March 1996. Aside from gradually or suddenly having much less hot water, the telltale was finding bits of plastic clogging faucet aerators.
There was a scandal, class-action suit, and settlement. But the terms of that expired several years ago, so if you find you have the problem, all you can do is try to deal with it. Even after replacing the dip tube and flushing the tank, you might still find plastic bits for awhile. But at least the water will again be hot.
Debacles aside, you should also be aware that even good plastic will eventually become brittle with age and hot water. We've found dip tubes in old water heaters that were split and broken. It's entirely possible for a water heater to outlive its dip tube. Simply replacing this inexpensive part can restore your tank's function to new and save you the cost of a new heater. So think about that before you run out and buy a new one if you experience this problem.
You may also want to flush out any built sediment. Check this out.
Dec 04, 2010 | Heating & Cooling
Water starts of hot but then starts to get cold.
You need to verify that you still have hot water. Sounds like you're running out.
Sep 28, 2010 | Home
Upper control panel flickers and will not allow me to control temo
how old is spa?
if new then circuit board maybe set on a mode setting that is used when being tested in the factory, locate dipswitch block on circuit board and move dip switch for MODE, should have a layout of dip switches on reverse of lid to control box
if older then you may need a new control panel (top side)
Adam Miller, Canadian Spa Company, UK
Aug 06, 2010 | Balboa Instruments Duplex Digital Panel 2...
Not enough hot water to complete shower. Noticed
If it is a new water heater it might be that the water supplies are crossed. The cold water should be installed on the right hand side of the tank or on the bottom if your tank hooks up on the side. If its an older water heater the dip tube may have broken off. This is a tube that runs from the top of your water heater on the cold side to the lower portion of the tank.It puts the cold water in the bottom of the heater which pushes the hot water to the top.To change the dip tube out you must disconnect the cold water supply from the 3/4 inch nipple at the top of the tank. Then with a pipe wrench unscrew the nipple from the tank it will have the remainder of the tube on it.You can get a replacement dip tube at a plumming supply. Installation is opposite of removal. If this is your problem I suggest you get a new water heater .Usually its caused from minnerals in the water or buy two dissimiler metals being connected together in the water piping system causing corrosion Your water heater will probably fail in the near future.
Dec 15, 2009 | Water Heaters
Water heater heats but not to same temperature
Try shutting off the gas, shut off the water, and drain the tank to remove any sediment that may interfere with heat transfer from the burner. If that doesn't do it, check the dip tube to make sure it is still intact. The dip tube directs incoming cold water to the bottom of the tank and the hot water is tapped from the top of the tank. If neither of those turn out to be the problem, check the thermo-couple. Since a gas water heater typically survives about 6-9 years, you may be better off just replacing it.
Mar 16, 2009 | Honeywell Water Heaters
Dryers Logo
Top Dryers Experts
