Question about Optimus Heating & Cooling
Optimus heater h6013 red light is not coming on pluged in and turned on full turned to high no red light no heat
4 Suggested Answers
  • 832 Answers
SOURCE: optimus heater h-4438
Check on the heater coil using the multi-tester. Set it at Ohms 1 x 10 position.
1. Switch it off and disconnect it .
2. Disassemble the electric heater.
3. Put the multi-tester probe (red and black) at each
end of the heater coil.
4. If the reading is almost zero, then it is okey.
Otherwise, you have to replace it.
5. Then, reassemble the electric heater.
6. Plug it back to the electric outlet, and switch on.
Posted on Nov 03, 2009
cadesertmax
  • 274 Answers
SOURCE: Heat does not turn to high.
It sounds like you are not getting enough gas at the main burner. Possible causes, bad regulator, easy to replace and relatively inexpensive. You could also have a partial blockage in the main jet orifice, not letting enough gas through. You have to take the head apart to service the main jet orifice, do the pilot jet orifice while you are in there. If you are not comfortable doing that, hire someone.
Posted on Jan 12, 2010
SOURCE: OPTIMUS H-4438 ELECTRIC HEATER ALARM LIGHT UP NO
I took it apart found nothing. Put back together took the plastic screw driver with the unit on,gentlly tapped the plastic houding opposite of the heat senser at the top of dish and it works!
Posted on Dec 13, 2011
Tylo sauna heater won't heat
if not calling for heat check temp sensor
Jan 19, 2012 | Tylo COMBI-U7 Sauna Heater
OPTIMUS H-4438 ELECTRIC HEATER ALARM LIGHT UP NO HEAT STILL ROTATE
Nov 04, 2011 | Optimus H-4436 Electric Heater
I have an Optimus H-5210 Infra-Red Heater and it's working great but last night while i slept, the pillow felt on top of it, burned a hole and i couldn't get the heater to turn back on. Is there a reset...
god please be carfull thousands of home fires start like this!!!!!!!
My guess is that a high temp cutout has opened. most likly it is not replacable.
Google search your model number / owners manual to see if there is resettable overtemp.
I was unable to locate but you may have more luck.
Remember infra-red heat warms items and objects in the room by absorbtion of infra-red waves this heater should not be near any flameable items! its designed to sit like 6 feet away from any thing and items in the room absorb heat energy then give it up to there surrounings.
please be carefull....
Mar 10, 2011 | Optimus H-5210 Infra-Red Heater
Optimus H-4338 The warning light came on and now the heater will
there's no reset, but unscrew the 3 screws in the back. Cut out white sleeve that covers the red & white wires. Take the fuse out from beginning to end. Attach the white & red wires directly. The fuse is not needed. Wrap w/ electrical tape. You, me and everyone that has bought this heater had the same problem. I called customer support. This is what they told me.
Dec 09, 2009 | Optimus H-4436 Electric Heater
Optimus heater h-4438
Nov 03, 2009 | Optimus H-4436 Electric Heater
Optimus H-4438 Electric Heater
Optimus electric heater can be found on amazon, click here and take a look: Amazon com optimus electric heater. I hope this was helpful. Cheers
Jan 10, 2009 | Optimus H-4436 Electric Heater
Alarm light staying on.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Feb 22, 2008 | Heating & Cooling
Presto HeatDish
buzz? is this heater an infrared or are the heat coils exposed?
Oct 30, 2007 | Presto HeatDish Compact Heater
Heating & Cooling Logo
97 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
