Question about Canon imageRUNNER iR C4080 Color Copier
How do I solve shadow printing in canon irc4080
2 Suggested Answers
SOURCE: canon mfc 4350 d printing
I have had a similar problem since purchase 1 year ago. Mine has this issue on first 2-sided copy I print, problem is on the second side only. I disassembled the machine and could not discover the problem. However I did notice one paper transport roller (there are $) was askew. After reassembly all was well for about 40 copies then problem returned, I will remove that transport roller and retest machine
Posted on Jan 30, 2011
How to connect a 3 computers to one photocopier machine using an IP address.
As all your PCs have Internet connection, I'm assuming that you have some kind of "network" already installed.
On each PC connected to LAN (Local Area Network) use "add printer wizard" and choose "add network printer" option. The wizard should be able to find your Canon device.
Oct 16, 2014 | Computers & Internet
How can I fix canon mx 452 when it prints a shadow
Are you using a reconditioned cartridge?
If so use a real Canon cartridge
Aug 30, 2014 | Canon PIXMA MX452 Wireless Office All In...
Printing shadow
Hi Christian,
There some possibilities of this problem: drum cartridge / transfer belt / transfer is exhausted, laser scanner assy is faulty.
Jan 14, 2014 | Canon imageRUNNER iR C4080 Color Copier
Canon irc4080 error Eoooo12
You need re-install the Delivery Feeder Unit
follow the step on
http://support-th.canon-asia.com/contents/TH/EN/8200281600.html#2
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Canon imageRUNNER iR C4080 Color Copier
How do I print the configuration report page on the irc4080?
If your looking to do a configuration report of the copiers internal settings you must be in service mode level 1 and under Copier>Function choose Misc-P then P-Print. Now push OK and within 30 seconds the machine will print the internal configuration. You can do this with all newer Canons.
May 27, 2011 | Canon imageRUNNER iR C4080 Color Copier
I have canon lbp 2900 printer when i print first line shadow is also printed in the middle of page and middle line shadow is also is printed in the last of page. and some of line shadow is also printed.
Repetitive ghosting defects like this are caused by either a bad drum in the cartridge or a damaged or worn fuser assembly. Try a different cartridge first, but make sure you print at least 50 pages to make sure that any toner residue is cleaned of the fuser in the printing process. If the defect is still there then you will need to either repair or replace the fuser.
May 06, 2011 | Canon LASER SHOT LBP-2900 Printer
I have changed from Broadband to Wireless and now my Canon IRc4080 won't print. I have turned everything off, turned it all back on, checked the plugs, changed the cable between the printer and my switch...
I would print out the user data list and see if these settings are what you had before. If these are correct, I would use the CMD function of DOS and ping the address of the copier. If connected correctly you should get a reply. You may have to go the the Canon support site and download the setup installer for driver software. http://www.usa.canon.com/cusa/support/office/color_imagerunner_copiers/Color_imageRUNNER_C4080_C4580_C5180_C5180i_C5185_C5185_PRO_C5185i/color_imagerunner_c4080#DriversAndSoftware
Pick the OS you're using and look for the setup installer ( usually a large file, has other copiers along with yours). Run it, follow instructions, and will it try to find the IP address of the copier. If it does, it should come up with the address of the data list. Hope this gets you in the right direction.
Jan 26, 2011 | Canon imageRUNNER iR C4080 Color Copier
Canon mfc 4350 d printing with shadow.or double printing is coming out .how to solve
Jan 10, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
HP CP1515N ONly prints half a page
There are 2 reasons for this either the ink is drying out nor your page settings isnt set to the correct size of the paper you are printing to.
Apr 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon imageRUNNER iR C4080 Color Copier Logo
old marine
old marine
