Question about Boating
Where is the water discharge on a 1973 2 cyl. Evinrude 2 stroke outboard engine?
SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Posted on Jan 05, 2009
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
finish line
  • 207 Answers
SOURCE: Will not start
if you have no fire 9 times out of 10 it is the cdi
Posted on Jun 27, 2009
  • 70 Answers
SOURCE: need firing order for a 86 chrysler outboard boat engine
Firing order 1 2 3 is common on most three cylinder outboards. 1 3 2 is the only other combination.
Posted on Jul 26, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
! quart of 2-stroke pre mix oil would be fine for 6 gallons of gas.
Apr 17, 2017 | Boating
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Evinrude motor problems
clean the carb jets etc and check fuel pump diaphrams not hard or perished ! balance the carbs also !
Aug 05, 2014 | Sierra Outboard Starters Johnson/evinrude,...
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
The manual tilt is locked in the up position, have been unable to lower the motor from a trailering position.
lift the engine to release weight !if siezed heat up and grease the joint till free !
Sep 04, 2013 | Seloc Marine Repair Manual...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Boating Logo
98 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
