My mav5000aww began making a weird noise when spinning and then came to a stop and doesn't spin anymore
    Problem Solver:
  • 10 Answers
Sounds like it threw the drum belt, which then bound up in the tensioners around the drum.
Posted on Jul 21, 2009
Matshita DVD-RAM UJ8A2AS Fails to Read CDs/DVDs
You probably fubar'd the drive when you attempted to uninstall the bios. Only the hands of an experienced drive specialist can help you.
May 14, 2013 | Computers & Internet
Won't read any kind of disc it spins and stopped like 3 times and doesn't move anymore
Sounds like you later lens has been damaged or is dirty. There is a cleaning kit at Walmart. If that doesn't work, google a local repair shop.
Feb 16, 2013 | Video Game Consoles & Games
Hi, for some reason, after Windows 7 has loaded the fan stops spinning on the Ageia PhysX card. The fan also makes a weird noise which it never used to do. Do u know what's wrong with it? It's...
In BIOS the fan always runs at full power, in Windows the speed is supposed to be automatically adjusted, depending on how heated the processor is. In your card it appears that the fan is dying, no longer capable of running at anything but the full speed. You will have to replace it - follow this
http://www.squidoo.com/video-card-fan-replacement
May 22, 2011 | BFG Technologies AGEIA PhysX 128MB GDDR3...
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
LG DLG2526W it just started to make a weird noise unitl it wouldnt spin anymore. unplugged it but still wont spin
The belt for the drum has a tensioner to keep the belt snug while running. The tensioner has a roller that incorporates a bearing to make it run smoothly. When the bearing goes bad the roller binds receiving a flat spot on it so when it turns it makes the belt snap very quickly making the belt to slap the drum everytime. It does make a lot of noise I know for I heard a lot of them with this problem. No since it does not turn the belt has finally broke so you need a tensioner roller and a belt which are sold together by most manufacturers
Apr 05, 2010 | Dryers
Won't spin makes weird noise.
Could be the motor coupler, transmission, or motor. Will it agitate now?
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
482 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
