Question about Garden
The mower does not start. No grinding or clicking. Could this be my battery?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 975 Answers
Gloria, yes it may be the battery, a bad connection at the battery or a bad ground at the frame. it could also be a blown fuse. start with the battery and clean all connections.
Posted on Dec 16, 2016
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Mowing yard and stopped to go inside. Come back out and mower turned over but would not crank. Kept trying and it started clicking. Rocked the mower and it started. now does same thing but won't start
Check your charge in the battery. Clicking usually is dead battery. If the battery is good, starter may be bad (or at least the starter solenoid).
May 04, 2015 | Garden
Engine will not start but solenoid grinds
SOLENOID DOES NOT GRIND FOR IS NO A MOBIL DEVICE, IT MIGHT BE THE STARTER WHAT IS NOT WORKING, SPECIFICALLY THE ACTUATOR THAT MIGHT BE STUCK, DISMOUNT STARTER AND CHECK SPRING AND GREASE THE SHAFT NO TO MUCH.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Sep 05, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Why won't my craftsman mower turn over/ start ?
Check your battery. The clicking you hear is likely the relay not getting enough voltage to close and latch and is just toggling.
IT IS NOT RECOMMENDED THAT YOU JUMP START YOUR MOWER WITH YOUR CAR AS YOUR CAR BATTERY IS LIKELY A HIGHER VOLTAGE AND COULD CAUSE YOUR MOWER BATTERY TO FAIL. CATASTROPHICALLY.
Jul 23, 2014 | Craftsman Garden
Wont start has never worked
it does click thats a good sign it sounds to me its a power problem battery not holding charge ? can it be wired if so plug it in and start it if it doesnt start its a motor problem if it does start its a a battery problem
Sep 27, 2012 | Black & Decker 19" Electric Lawnhog...
My husqvarna tractor won't start. It has a new battery but no clicking or anything when I turn the key. If I hook up a portable battery charger and try to start it, I hear a grinding noise but the engine...
have you checked the fuse? there is a 20amp yellow fuse under the hood just below the solenoid same side as the blade engagement switch.also be sure all your lock out switches are working or by passed.
Feb 06, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Will not start
I have a feeling what happened was you shorted out the ignition switch, somehow. If you can get behind the switch without much trouble, try to jump the wires together 2 at a time just to see if it will jump the , lights, starter, ignition, one of the 3. or get a voltage tester, it will do the same thing. There is a fuse on there in the line, sits next to the battery. check it. Hope this helps,
May 06, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Put battery cables on wrong
For starters remove the battery and take it back to the store where you bought it and have them test it. Your solution may be to purchase another battery.
Apr 21, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
