Question about Kubota Garden
Kubota tractor b3000 front load control lever not working correctly
3 Suggested Answers
  • 62 Answers
SOURCE: Headlamps quit on L4200 kubota tractor, Wireing
CHECK THE FUSES
Posted on Sep 25, 2009
  • 189 Answers
SOURCE: murray model series 760 lawn tractor speed control. Tractor won't move.
Well the lever is obviously not reaching the motor so fix the lever
Posted on Feb 18, 2015
How to replace pto wire on Kubota L2800
No need to remove any panels. the bottom end attaches to a lever on the right hand side of the transmission. Can be reached from under the tractor. There was an update on the control cable which changes the angle of the bracket on the top end so the wire does not bend and break so quickly. check with you dealer to see if yours qualifies.
Jan 01, 2017 | Kubota Garden
How to remove/replace Kubota b7100 three point hitch hydraulic control lever
Try you tube, type "How to remove/replace Kubota b7100 three point hitch hydraulic control lever." there are videos.
Aug 20, 2016 | Kubota Garden
PTO lever engages in the wrong position in a Kubota ZD323.
Check and make sure that any links are not bent and make sure that the switch that engages the PTO is not out of adjustment.
Jul 14, 2016 | Kubota Garden
Need a free kubota repair manual for a b2710 tractor
Here is a link to the work shop manual, I believe that is what you are looking for! Kubota b2710 tractor Free Pdf Manuals Download
hope this can help you out, and don't forget, you can check out our site for parts! Lawn Mower Parts
Sep 23, 2015 | Kubota Garden
ONLINE PARTS DIAGRAM FOR KUBOTA ZD331
Go to Kubota Kpad Site. You must be running Windows Internet Explorer or the correct add-ons to access to site. Also you need to know which size deck you have.
Here the front part link.
Kubota Tractor Corporation Parts
Apr 05, 2015 | Kubota Garden
Where could I find a cylinder head for Kubota L3010HST?
Your Kubota should have it. You will need your serial number as there is three heads for this tractor.
Another option is your tractor savage yard. There you would your old head to match up the correct one.
Apr 01, 2015 | Kubota Garden
Kubota L2250 DT wiring diagram
You can download:Kubota Tractor L2250, L2550,L2850,L3250 2WD 4WD Operator Manual
This Manual Covers
1. Servicing of Tractor
2. Specifications
3. Operating New Front Mower
4. Instrument Panel and Controls
5. Lift Link and Hydraulic Control
6. Wheels, Tires and Tread
7. Operating
8. Maintenance
9.Check and Maintenance
10. Adjustments
11. Troubleshooting
12. Long-Term Storage
13. Lubricant Specifications
14.Wiring Diagram
Jul 03, 2012 | Motorcycles
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
Kubota B3300SU. Tractor was running, I got off to adjust a rope and tractor shut off. Now the lights come on as usual before starting but the engine does not turn over. Head light come on etc. only 20...
Let's try the obvious first, the safeties. I now I sometimes forget to turn off the PTO or forget to put the clutch down and my tractor won't start.
You may have hit a lever with your body climbing off the tractor and this is causing the problem. Check all the levers to see if they are in the correct position for starting.
Turn off the PTO (attachment drive) sit on the seat, put the tractor in Neutral, push down on the clutch. Please read the manual section on starting the tractor.
Wiggle the transmission lever (or foot control) when you have the key in the start position. Sometimes the "neutral" position is a little bit off.
Let me now if this fixed it and if it doesn't we can continue this conversation.
Jan 10, 2011 | Garden
2003 B3000 v-6 idles rough but does not stall and runs well at highway speeds
Try turning on the ac or turning the steering. The increased load on the engine should lower the the rpm. If the Idle Air Control valve is working correctly it should sense the load and maintain the rpm or even increase it a bit.. Also this should be cover under warrenty.
Jul 30, 2009 | 2007 Mazda B3000
Garden Logo
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
