Question about Belkin (F5D7230-4) Router (587009)
Receiving request for Belkin PIN from Linksys Router
Receiving request for Belkin PIN when attempting to connect to a Linksys router.
    Master:
    Sergeant:
  • 226 Answers
Hmm you shouldnt recieve a belkin pin request when you are connecting to a linksys router
Posted on Jul 20, 2009
I have a linksys wrt54g v2.2. Its about 5 years old. My wireless connection doesn't show up on my network list and when I connect the router to my pc I can't access the 192.168.1.1 website to change my...
Sounds like the router has failed, I have Belkin -N router that I'm pleased with, generally, Belkin, Netgear, D-Link and Linksys are all rated pretty evenly
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
Tip
Wireless Network Reset - Belkin
If you are unable to connect your laptop wireless to your <b>Belkin</b> wireless access point/router, the <b>easiest</b> and<b> fastest</b> way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.<br /><br /><br /><br /><b>Reset your router:</b><b><br /></b><br /> <ul> <li><b>Unplug</b> your <i>DSL/Cable</i> <b>modem</b> from power (not your access point/router) Leave this unplugged for now</li></ul><br /><br />Next <ul> <li>On the rear of your<b> Belkin router </b>you will find a small RESET button</li> <li>With the power still on the router,<b> Press</b> and<b> hold</b> (with a pin/pen tip) the <b>RESET</b> button for 10 seconds.</li> <li><b>Release</b> the RESET button a wait 15 seconds for the router to reboot</li></ul><br /><br />almost done.... <ul> <li><b>Unplug</b> your <b>Belkin</b> router from power</li> <li><b>Plug</b> your DSL/Cable <b>modem</b> back in to <b>power</b></li> <li><b>Wait </b>1 minute for the modem to boot up</li> <li>Be sure the ethernet (cat5) cable from your <i>modem</i> is securely plugged into the <b>WAN port</b> on the back of your Linksys <i>router.</i> This is usually labeled <i>WAN</i> or<i> Internet</i> above the jack</li> <li><b>Plug</b> your Belkin <b>router</b> back into power.</li></ul><br /><br />You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.<br /><br /><b><br /></b><i><b><br /></b></i><i><br /></i>Magoo
on Mar 13, 2011 | Computers & Internet
My Belkin F5d82334v3 router flashes orange continuously
Contact belkin for the IP address to change your router setting internally. For example: Linksys is 192.168.1.1
Putting this address in your address bar will dial you into your router setting if you have a Linksys router. Each router manufacturer may have a different IP address. Hope this helps! Good Luck!
Mar 15, 2010 | Computers & Internet
Setting up Linksys Wireless Router for Satellite
In Windows, run "cmd". Type "ping google.com". If you can ping google.com, the problem is with the websites you are trying to surf. If you cannot ping google, there is a problem with your connection. This sounds like a used wireless router
You might need to configure it. See this: https://www.linksys.com/us/support-article?articleNum=139668#H2
Oct 16, 2017 | Gateway Belkin 54g Wireless DSL/Cable...
I have a Linksys by CISCO Wirless-G WRT54G2 Router connected to a High Speed Ethernet Modem and to my Desktop Computer. It gets fairly good signal sent to my laptop across my house. I also have a Belkin...
If your computer has 3 bars of signal, it's ok, don't mess with it.
If you want better reception, you can connect the Belkin wireless router near your notebook with a cable to the Linksys router.
Nov 04, 2009 | Computers & Internet
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Where do i find the pin for my router
what kind of pin for what? there is power jack and ethernet cable jackbehind the router
Jul 23, 2009 | Linksys Wireless-G WRT54G Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Would a neighbors linksys router interfere with my belkin connection?
do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Oct 29, 2008 | Belkin (F5D8231-4) Wireless Router...
Number of computers able to connect?
You set the number in the panel.
Make sure its set to DHCP, here is a screenshot of mine:
http://img66.imageshack.us/img66/8438/imagemi4.png
click that link ^ to see pic
Now to access your router pane ou need to get your default gateway and put that address in your browser then login.
To find ur default gateway:
start>run>type cmd> then type ipconfig/all
Good luck,
Cam
Oct 16, 2007 | Belkin (F5D5231-4) Router
Belkin (F5D7230-4) Router (587009) Logo
934 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
