Question about Cell Phones
How to light up display - Cell Phones
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Backlight burned out, how do I replace it?
The back light is typically an integral part of the LCD display, so you may have to replace the entire display. On some displays, the touchscreen and back light connections are separate from the display and on some displays, these connections are soldered to the LCD display. Trying to take apart the LCD display just to change the back light can result in breaking the LCD display. You are better off just replacing the entire display if you can find it for that model.
Oct 15, 2013 | Garmin GPSMAP 176C GPS Receiver
Nokia 1209 display lights not coming
Hi, when a phones display light does not come on,there is an IC that makes the display light comes on. When the IC that makes the display light is bad, it will not make the light come on.
When you replace the IC, the display light will come on again.
Take care.
Sep 26, 2010 | Nokia 1209 Cell Phone
Display light does not turn off in sigmatel t33i. When the phone is switched on, the display light turn's off, as the time setted in the settings. But after a incoming call or entering in multimedia, the...
Display light does not turn off in sigmatel t33i. When the phone is switched on, the display light turn's off, as the time setted in the settings. But after a incoming call or entering in multimedia, the display light does not turn off in the sigmatel fxd t33i..
May 04, 2010 | Cell Phones
Display prblem
setting me jaake display light ON kariye. if it does not work then its a hardware fault. take it to nokia care.
Jul 28, 2009 | Nokia 1209 Cell Phone
My nokia 6085 mini display wont light . You can see the time displayed but it is dark.
change the display IC near the main board strip connector, there r two ICs the one on the right side is for mini display , re heat it if it doesn't work after changing the IC ;)
Jun 06, 2009 | Nokia 6085 Cellular Phone
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Feb 22, 2009 | Yamaha RX-V730 Receiver
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
