Question about Kyocera Copystar CS-1620 Black and White Copier
KYOCERA 1620 ERROR CODE C7760 - Kyocera Copystar CS-1620 Black and White Copier
  • 66 Answers
SOURCE: Copier fixing problem
Hi
The A-3200 error indicates a scanner lamp problem.
It can either be a loose connector or more likely a lamp or inverter PCB.
Another cause can be incorrect shading position, by moving the contact glass this may fix it.
Posted on Jul 15, 2009
shawn38
  • 200 Answers
SOURCE: photocopies displays and error message that reads 400 then C-6
It most likely can be reset over the phone. Go to www.gfbm.net and call. They can walk you thru reset over phone whach should correct the problem at no charge.
Posted on Feb 19, 2010
M2Tech1
  • 313 Answers
SOURCE: Error E31
this is an error code for slow warm up you should pull the fuser out and check the thermistors and condition of the rollers. sometimes the thermistors get caked in toner so they cant read the temps correct. if you take the unit apart you should be able to detect the toner build up. a soft clothe and some WD40 may be able to clean it off but be ccareful as too rough may clip ther resistor off.
Posted on Jul 12, 2010
SOURCE: Kyocera KM-1620 as a printer??
please tell me about km 1620 erorr code 7760
Posted on Mar 08, 2013
  • 3698 Answers
SOURCE: ALL KYOCERA MITA 1620 ERROR CODES
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Kyocera-Mita&model=KM1620
Posted on May 21, 2014
Error code C7760 in Kyocera km 1635 copier help me
Drum type mismatch problem B The drum type is undefined.
Causes
Defective software of the engine PWB. Defective engine
Change the drum unit
Jul 10, 2017 | Kyocera Office Equipment & Supplies
C7760 in kyocera KM 1635
C7760 Description Drum type mismatch problem B The drum type is undefined. Causes Defective software of the engine PWB. Defective engine PWB.
Jul 19, 2014 | Kyocera Office Equipment & Supplies
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Error code A3200 for kyocera km 1620
how to repair kyocera km 1620, showing error message "A3" "200"
Mar 31, 2013 | Office Equipment & Supplies
Kyocera 1620 error code c-4 000
that code, unfortunately, means your laser unit has went south. you definetly have to call a tech on this as it is quite a job to even get to the laser.
hth
razors
Mar 08, 2009 | Copystar CS-1650 All-In-One Laser Printer
Copystar/Kyocera 1620 error code: "C-6" and "400" (cylces back & forth once a seond)
so, just enter 10871087, press start, after enter 163, press start. thats all.
Feb 04, 2008 | Copystar CS-1650 All-In-One Laser Printer
Kyocera Copystar CS-1620 Black and White Copier Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
