Question about Marantz Audio Players & Recorders
I have marantz 74sr96 , when i switch it on , at the screen show MASTER -62db. and can not on .. what the problem ? how to fix it?
I have sky tv and a marantz system, marantz system flashes pcm dig and tv loose signal intermittently, help
Your Sky box might need a firmware refresh. Switch it off at the mains socket. Press and hold down the BACKUP key on the SKY BOX (not the remote). Switch on at the mains and keep the backup key pressed down until the TV shows an info screen that the box is updating.
Allow the box to complete the cycle.
Try your system again.
Sep 02, 2014 | Marantz Audio Players & Recorders
I moved my marantz plasma tv and now it wont turn on
Some of these have a master power button on bottom or rear, larger square push switch, it may have got turned off from power there....
Dec 15, 2012 | Marantz PD-6140D 61 in. HDTV-Ready Plasma...
My marantz sr7001 has sound but the video wont show on the tv
Video processing section circuit should be troubleshooted. Seek tech support.
Jun 03, 2012 | Marantz SR7001
How to reset marantz sr4003
marantz SR 4003 how to reset (hard reset ) remove power plug from power .Take cover off locate ic 12 (24 c eeprom) short pin 5 to ground while plugging the power in .Unit will show clear on fl screen .if the unit trips again check channels.
Jan 04, 2012 | Marantz SR4003 Receiver
Marantz sr-96 receiver master volume not working
Possible that the analogue to digital converter is faulty, possible failure of the potentiometer and the motor drive.If the volume does increase with the remote then it is possible that the POT or the circuit to it is faulty. check this D/A converter.
Dec 14, 2011 | Marantz Audio Players & Recorders
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
Cant get mp3 files from my marantz pmd620 to play on my mac
Well, try copying them to a folder on your computer. Also, make sure that the files are not proteced with DRM. If these fail, open iTunes. Select all of the MP3 files and drag them into your library. That should fix it.
Feb 04, 2009 | Marantz PMD620 MP3 Player
Screen Calibration
I'm a french customer with a Marantz RC5400 wich has a screen LCD broken but the touchscreen is OK
I don't have the fix for your problem but I'm searching for a screen replacement at low cost...
If you always have your Marantz with the touchscreen problem, I'm interested for a deal
Thanks
Dec 06, 2007 | Marantz RC5400 LCD Touchscreen Remote...
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
48 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
